Major Oil Consumption Problem...looking for help
Old Mar 20, 2012 | 01:15 PM
mondi's Avatar
mondi
Unfortunate!
Thanks for all the help guys!
I'll just wait till the motor gets worse then I'll get a new one or something. I've had the OC issues for quite some time and as long I keep adding oil it runs fine. Had the car 5 years and just had to get the transmission changed onced, and that was within the first month of buying the car.
Just got to keep my eyes open for a used motor and then work from there.
I'll make sure I don't get my car tuned at AAM again :-)
Old Mar 22, 2012 | 02:58 AM
Originally Posted by mondi
Yes, 15 qts, not 5 qts. Like by 1000 miles if I hard brake the engine oil light comes on and off. I've recently had the check engine soon blinking as if it misfiring.
I don't know if I've seen blue smoke but if I rev the engine there is smoke
And I feel like the car feels sluggish now.
My 350z looks so good but motor so messed up
Sluggish is an understatement. You may be running 80 percent of spec compression in each cylinder. Figure 20 percent drop in peak horsepower.
Old Mar 22, 2012 | 03:07 AM
Better sooner than later. Motor will not fix itself. It will get worse.
Oil use sucks.
Performance sucks.
MPG sucks.
At some point oil will not lubricate cylinder walls. Oil pressures falls fast. The motor will seize.
Old Mar 22, 2012 | 05:39 PM
KAT_Ayanami's Avatar
KAT_Ayanami
Unfortunate!
AAM?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
