Motorsports The Z in its Natural Habitat
Launch Technique
Old Feb 24, 2003 | 08:08 AM
DPK's Avatar
DPK
Default Launch Technique
I'm trying to figure out the best launching technique for a stock Touring Z on OEM tires on a track. Any suggestions?
Old Feb 24, 2003 | 09:17 AM
BigBadBuford's Avatar
BigBadBuford
I'd run your tires around 27 psi to start, and give them a little burnout before you run. Don't go through the water! I would try to launch around 2500-3000 feathering the clutch. If the tires don't hook, lower your tire pressure a little at a time until you get the best results.
Old Feb 24, 2003 | 09:34 AM
DPK's Avatar
DPK
Thanks. What about the VDC? Should I turn it off?
Old Feb 24, 2003 | 11:41 AM
XBS's Avatar
XBS
Veteran
Definitley turn your VDC off when u race it is a huge diffrence since if you shift to fast/hard into 2nd and ur wheels spin a little they will lock and the vdc will cut ur throttle since we have the drive by wire but VDC is great when it comes to the turns saved me a few times
bcoffee20
Nov 19, 2015 06:39 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Brantwilliams13
Sep 16, 2015 05:03 AM
