Motorsports The Z in its Natural Habitat
Launching 1st gear
Old Apr 2, 2003 | 12:32 PM
mquejado's Avatar
mquejado
Arrow Launching 1st gear
I just broke in my Z and am doing tests at what is the best RPM to launch off 1st gear for when i race.
From any well experienced Z driver, at what RPM do you find it best to launch off the line when racing?
Old Apr 2, 2003 | 04:53 PM
Rizzness's Avatar
Rizzness
I also am interested in experienced drivers' comments!!
ZZ
Old Apr 2, 2003 | 05:36 PM
350zSpeedRacer's Avatar
350zSpeedRacer
Then let's put this in the Racing Forum, so you'll get more of an "educated" response. No offense to ANYONE out there.
Thread moved.
Old Apr 2, 2003 | 07:04 PM
Shift_Speed's Avatar
Shift_Speed
i basically have it to the point where the car is about to move and jack up the e brake... and then slip out the clutch.... i dun think my way is the best but for me so far this seems the best way
Old Apr 3, 2003 | 07:12 PM
stevo's Avatar
stevo
hey rizz, are you orignally from houston?
Old Apr 3, 2003 | 08:08 PM
newmexicoZ33's Avatar
newmexicoZ33
...ok, this might be more detailed than what you want to hear, but here it goes. At the track, I have found that launching at about 2750rpms is the best. I feather the clutch just enough to get the car going (which produces a little wheelspin...the key here is to minimize wheelspin as much as possible) then floor it and go from there. I also tried feathering at 3000rpms but I seemed to be getting too much wheelspin. On the streets, I have found that I can dump the clutch right at 2500 rpms without wheelspin/hop so the car gets going right away but takes longer to build up rpms. When I dump at 2750 I get a mix of hop and wheelspin (like it doesn't quite grab) and a dump at 3000rpms leaves nice little burn marks on the asphalt. For the streets I would recommend slightly feathering the clutch at 3000rpms just to get traction and then flooring it. Now keep in mind that my advice is based on a LSD-less model. Also, I am at ~5400 feet so the car won't run as strong as at sea level. Hopefully these will at least be some starting/reference points.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
