NA Build Inside....Soup to Nuts :)
Old Sep 13, 2010 | 08:19 AM
  #1101
Zazz93's Avatar
Zazz93
Hey Adam, did your engine get noticably louder after the build (mostly the cams)?
Old Sep 13, 2010 | 09:20 AM
  #1102
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I really dont remember, sorry
Old Sep 13, 2010 | 09:59 AM
  #1103
Zazz93's Avatar
Zazz93
Cool just wondering... even the Fuji sounds loud now, but clearly a step in the right direction (decibel-wise).
Old Sep 20, 2010 | 11:30 AM
  #1104
Z1 Performance
Former Sponsor
Weather has been amazing here but I hvae not had any chance to drive the car lately - I guess the clock was not only ticking on my Y pipe but my test pipes too as I found a very slight crack on either one, resulting in more really annoying noises. Replacing them tonight with some Turbo XS units, so I should be back to normal soon
On another front, got a new set of coilovers that we will be putting through their paces very soon - Ohlins Road and Track Series
http://cornerbalance.wordpress.com/2...-for-the-350z/
Old Sep 20, 2010 | 02:12 PM
  #1105
MREDDLE's Avatar
MREDDLE
I have always wanted Ohlins coilovers... To bad they are not made for my car. Very nice. Please let us know how they are.
Old Sep 20, 2010 | 02:45 PM
  #1106
2004Black350z's Avatar
2004Black350z
Exhaust Whore
why not replace tps with ARTs?
Old Sep 20, 2010 | 03:12 PM
  #1107
Zazz93's Avatar
Zazz93
Can't tell, the springs look like OEM bucket style but the rear shock has an odd config... Are these a spring bucket delete style or OEM?
Old Sep 21, 2010 | 11:51 AM
  #1108
Z1 Performance
Former Sponsor
we don't sell Motordyne products; only makes sense for me to use what we sell
  #1109
Z1 Performance
Former Sponsor
they maintain OEM rear geometry
Old Sep 21, 2010 | 01:58 PM
  #1110
2004Black350z
Exhaust Whore
understandable but i thought u was trying to squeeze every hp out of it
Old Sep 21, 2010 | 02:12 PM
  #1111
0jiggy0's Avatar
0jiggy0
If that was his goal I'm sure the car would be a 4.2-4.5L with 280 degree cams with 12:1+ compression ratio.
From what I've notice his idle is pretty normal with a nice little bit of lumpyness. I heard the car pass me once recently while standing and the car is quite loud. A nice clean loud, but it is loud. Not a hint of rasp and very deep.
Old Sep 21, 2010 | 02:18 PM
  #1112
2004Black350z
Exhaust Whore
yea i know jigg i was just saying getting every hp out of his CURRENT set up. Post a vid of the car and flybys. I would love to hear it
Old Sep 22, 2010 | 05:36 AM
  #1113
Z1 Performance
Former Sponsor
We posted a video somewhere in this thread at somepoint and it's on our youtube channel as well (not much of a channel, just a few vids there). Sounds a bit different now with the change in intake manifold and now with the 06 airbox. The car actually does have a bit of rasp (at least that I hear in the cabin, been a long time since I've heard the car from a bystanders vantage point) in the lower spectrum of the midrange, but it's not a big deal to me at all. It has a nice crisp, tight sound to it through the rev range, that gets fairly deep as well. It's pretty loud at WOT (not nearly as loud as jiggys!), but cruising on the highway is very pleasant, no drone or anything like that, which is nice because it lets me enjoy the stereo
Old Oct 4, 2010 | 01:01 PM
  #1114
homeboynyc's Avatar
homeboynyc
nice!
Old Dec 7, 2010 | 07:06 PM
  #1115
Z1 Performance
Former Sponsor
haven't updated anything here in a while, so here goes:
had an exhaust leak...turned out to be both a Y pipe issue (3.5 years scraping the flex section finally wore a hole), and one test pipe had a weld that cracked a bit. Replaced the test pipes with Turbo XS ones, and had the flex sections cut out of the Y pipe altogether and just replaced it with straight solid piping. Won't be a long term solution, just couldn't stand the leaky exhaust. I'll figure out a more permenant solution in the spring but this will work for now
Suspension installed, car realigned. Didn't cornerbalance it again, will probably do that in the spring too. This is, without question, the best suspension I've ever used on these cars. Tons and tons of height adjustment, but very meaningful dampening adjustment. It just does everything well.
While doing the alignment, I noticed the pumpkin leaking. Yeah, the same pumpkin that took so much custom work to get done...had a leak Not quite sure what caused it (we have a theory) but it was coming right from the front (engine side) and was beginning to coat the rear section of the midpipe, as well as my back bumper! Just took it down, swapped in a new seal and pinion nut (thanks Alex) and it's now ready to go back in.
engine wise I haven't done a thing, and have no plans...lots of ideas, and "wouldn't it be cool ifs...", but just going to leave it as is for the time being.
Old Dec 16, 2010 | 11:36 AM
  #1116
scottfreeman80's Avatar
scottfreeman80
Default nice ride!
Beautiful n/a setup man. Just spent a few hours catching up on your build, only advice would be to shave the rear wiper/hatch to make it cleaner looking my buddies z has a apr single turbo kit with a built motor in it and has had a lot of problems with his haltech emu (mainly the cpu shorts out)...any rec's on a better unit?
Old Dec 16, 2010 | 11:52 AM
  #1117
Z1 Performance
Former Sponsor
thank you
I've had the Haltech for awhile now and no issues - did it get it from a direct dealer?
Old Dec 20, 2010 | 04:47 PM
  #1118
scottfreeman80
yes, dealer direct, straight from haltech. we changed it out this weekend with a new unit and seem to have zero issues so far. good thing it was still under warranty! they claimed it was a "bad batch" or something to that nature. Couldn't get any spark out of the engine, changed back to stock ecu and it fired right up. New unit works perfect now. Just wondering if you had tried any other similar units other than the haltech???...oh and were now tuned at 330hp 315tq on 3psi for "mileage" she is gonna be one fast ***** here after breaking in the new engine!
Old Dec 21, 2010 | 05:10 AM
  #1119
Z1 Performance
Former Sponsor
I previously used a utec when the build was first done and changed to the haltech about a year and a half ago
Old Jan 22, 2011 | 03:35 PM
  #1120
leozim's Avatar
leozim
any updates with your ohlins?
