New dyno numbers: 294 rwhp
Old Nov 19, 2007 | 03:41 PM
  #41
rednezz's Avatar
rednezz
I just want to point out that I am not disappointed in the power I am making at all. However, I would like to make more power. The easiest and least expensive thing to do first is to dyno with open test pipes. Then I can try different headers and the Cosworth manifold once it is released. I am confident that I can pick up another 10+ rwhp by experimenting with the headers, exhaust, and improving the intake system.
Old Nov 19, 2007 | 03:46 PM
  #42
TheJerk's Avatar
TheJerk
Cams, and Cam-timing are key. I think Orsis allows this (only up to 6600rpm though)
  #43
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Originally Posted by TheJerk
This is stupid logic.
A Bottle neck is a Bottle neck. I never understood someone saying Things like "in your build, its not worth it" The Nismo Exhaust most likely doesn't make power, and as RPM rise, he could be losing out on a broader power curve. I'm with Tony and Alberto on this one (big surprise)
The exhaust works just fine...a ~ 3 inch pipe, which is what a NISMO uses, is not a bottle neck at 300 whp, or 350 whp - one could argue the chambered muffler of the NISMO might be, but its all a balancing act of sound, looks and power - you're certainly not going to gain some magical power figure at this level by swapping exhausts.
Changing parts for the sake of changing parts is a waste of time and a waste of money, and rednezz has been through enough to know it. I'm just trying to help rednezz by sharing what I know. The issue with his setup runs alot deeper than what exhaust he has on the car - the rest is all semantics. When those fundamental issues are addressed, if at that point he wants to swap one exhaust for another, go for it - at least then it would be a meaningful test. But to suggest he does it now, as if the exhaust is costing him some mega amount of power, is humorous
It's an easy enough test to let the car run on the dyno with open test pipes and see how it does - you'll pick up a bit of power that way, but it's still not the reason the car is so shy on power. Given the parts, it should be making significantly more power that mine or Richies car, especially in the 5000 - 8000 ish rpm range.
Old Nov 19, 2007 | 03:48 PM
  #44
Z1 Performance
Former Sponsor
double clicked...whoops!
Old Nov 19, 2007 | 03:50 PM
  #45
Z1 Performance
Former Sponsor
intake wise, trust me, the car won't care when its sitting on the dyno what intake you're running
Short ram, cold air - when the car is stationary with the hood open, its of little consequence.
Old Nov 19, 2007 | 04:07 PM
  #46
rednezz's Avatar
rednezz
Changing parts for the sake of changing parts is a waste of time and a waste of money, and rednezz has been through enough to know it. I'm just trying to help rednezz by sharing what I know. The issue with his setup runs alot deeper than what exhaust he has on the car - the rest is all semantics. When those fundamental issues are addressed, if at that point he wants to swap one exhaust for another, go for it - at least then it would be a meaninful test. But to suggest he does it now, as if the exhaust is costing him some mega amount of power, is humorous
Definitely agree with you. To me its not worth the cost to swap an exhaust to gain 5 more rwhp (unless I was filthy rich). I know a good set of headers would really help...I have been asking around locally. I have personally seen what a good set of headers will do with a cammed car. I have alot of friends that have cammed their cars and picked up gobbs of torque and power by going from shorties to good set of long tube headers.
I mean intake manifold. I tried different intakes and it will not gain any power and usually loses power over the stock box. I even pulled the air filter out to see if I would gain anything and all I gained was 1 rwhp. LOL That tells me the intake tube and air box are fine...if there will be a restriction in the intake it will be the manifold not flowing enough on the top end.
Old Nov 19, 2007 | 04:13 PM
  #47
rednezz's Avatar
rednezz
UpRev tuned my car and changed my cam advance. I gained significant amount of rwhp that way. There seems to be a physical limitation to changing the VTC angle past 6600 rpm. It doesn't seem to be a software problem. Thats according to UpRev.
  #48
Z1 Performance
Former Sponsor
I've got a suggestion on someone you can talk to about headers as well - they will be doing a set for our other Z in the near future, and I'd be willing to work with them to do more of an "all out" type setup
Old Nov 19, 2007 | 04:29 PM
  #49
rednezz's Avatar
rednezz
Here is a dyno graph of one of the first dyno pulls after correcting the A/F ratio and timing but with stock VTC angles versus my latest dyno with the same timing table but corrected A/F and additional cam advance 2800 rpm to 6600 rpm.
I have also included the VTC angles that got me in the ball park:
@2000 rpm 45 degrees
@3000 rpm 53 degrees
@4000 rpm 50 degrees
@5000 rpm 35 degrees
@6000 rpm 27 degrees
Attached Thumbnails New dyno numbers: 294 rwhp-dyno2.jpg
Old Nov 19, 2007 | 05:38 PM
  #50
Z1 Performance
Former Sponsor
would love to see what the ignition timing curve looks like
Old Nov 19, 2007 | 08:02 PM
  #51
rednezz's Avatar
rednezz
I can't post the ignition tables but I can tell you that the timing goes from around 15 degrees around idle to a maximum of 37 degrees up top.
Old Nov 19, 2007 | 08:22 PM
  #52
Z1 Performance
Former Sponsor
gotcha....alot more timing than I am running
I PM'd ya...call those guys, hopefully they can help
Old Nov 19, 2007 | 08:25 PM
  #53
rednezz's Avatar
rednezz
Just got you PM. I appreciate it...I will definitely talk to them.
As far as the timing that is what made the most power...anything more or less and I just lost power after 37 degrees.
Old Nov 19, 2007 | 08:31 PM
  #54
Z1 Performance
Former Sponsor
I don't doubt it - I'm currently running max advance of 31 degrees - one of the things we want to do next time on the dyno is crank it up (my engine builder called my timing curve wimpy after I sent it to him ). We knew we had some room to go but it was hot and humid the day we tuned my car back in July, and since the motor was new, we figured we would leave it where it was.
Old Nov 19, 2007 | 10:23 PM
  #55
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Damn that's a sick setup...
I would love to see how you resolve the power fall-off though
Old Nov 20, 2007 | 02:53 PM
  #56
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Finally saw this thread, thanks to Z1 pointing it out to me.
That abrupt drop off looks a little bit different than air starvation. Hurry up and bring this baby down...i would love to have a crack at it! It's BEGGING to break 300whp.
Old Nov 20, 2007 | 07:50 PM
  #57
rednezz's Avatar
rednezz
The way the power climbs to 6200 rpm, I have no doubt if I could extend the peak power out to about 6800 rpm or higher this motor would be well over 300+ rwhp. This motor motor definitely has the potential. From 3000 to 6200 rpm the dyno graph looks exactly what the Tomei dyno predicted it would be like and that is still with not enough cam advance on the low end.
Old Dec 6, 2007 | 05:27 PM
  #58
TheJerk's Avatar
TheJerk
Are you not the same - who said that there was really nothing to gain by playing with cam angles? I'm taking everything you say for now on as a grain of salt.
Old Dec 6, 2007 | 05:36 PM
  #59
Z1 Performance
Former Sponsor
You really do live up to your screen name...congrats on being the king of taking things out of context
I said that about MY car with my setup, not about anyone else's. My engine mgmt choice doesn't afford me the ability to adjust VTC angles, nor would my cams even derive a substantial benefit by being able to reprogram them in the first place, as they are far milder than the cams being used on rednezz's car. If I ditched the UTEC and went with a standalone, then yes, I could adjust VTC as well, but at this time, I don't think it's worth the investment for me to do so. I am more than happy with my torque curve and horsepower curve, so I see no reason to change my engine mgmt at this time.
Withy rednezz's setup, obviously vtc mapping is critical - with mine, it's not
Old Dec 6, 2007 | 06:58 PM
  #60
DelayedZ's Avatar
DelayedZ
Can't wait to see once you make more adjustments, I see great things for this build
