Highest NA Torque?
Old Aug 2, 2008 | 10:37 AM
13SECZ's Avatar
13SECZ
I don't have the graph handy but if you search threads I have started then you will see it. It was on a DD but a sim correc. Factor was used, they stated it was equiv within 1-2 hp of what the dj down the road reads...they've proven that. My car pulls good, I have proven it against de and hour motors that I have run against with similar mods.
Old Aug 4, 2008 | 08:21 AM
Zquicksilver's Avatar
Zquicksilver
no one is calling you a liar... maybe the 4.08FD needs to be considered in the equation, i didn't see that!
i guess we can all agree...
notice that 75-77 lb/ft per liter at flywheel is a very high number for N/A
you have a very torque'y motor, congratulations
Zquicksilver
Old Aug 4, 2008 | 08:23 AM
13SECZ's Avatar
13SECZ
I know....but just stating the facts...
Old Jan 14, 2009 | 01:54 PM
darknightdrift's Avatar
darknightdrift
on my 03 i made 270rwhp and 260ft/lbs. tq that was before my cobb tune and headers. want to do another run soon btw i ran on a dynojet
Old Jan 15, 2009 | 06:33 AM
ct350z's Avatar
ct350z
i call B.S.!!!!
Old Jan 18, 2009 | 03:02 PM
9shelby's Avatar
9shelby
my 05 is running 300whp and 271 trq on a mild bolt on build with a tune
Old Jan 18, 2009 | 03:32 PM
T_K's Avatar
T_K
Originally Posted by Q45tech
Where people get confused is that driveline loss increases with rotational speed of components, so you cannot use the same 15% for HP peak rpm as you do for mid rpm torque where losses might be 10% or less!
The only way to measure engine output at flywheel is to pull engine and place on a dyno..............all this reverse calculation from a chasssis dyno is full of errors.
You guys need to reread this post and his previous one. You can't compare dyno to dyno, or car to car. You can only compare the same car with its own baseline. To make a more accurate comparison of torque, you can't compare raw numbers to each other. Take the percentage increase of your current torque compared with your baseline torque, then use that number to compare with others.
Even in this case, dyno should be the same dyno and conditions should be similar, although the result is already inaccurate so correction factors for ambient conditions will play a small role. In any case, it's better than measuring raw numbers, which means nothing.
TK
EnjukuRacing
Sep 30, 2015 06:55 AM
RWDBajan
Sep 17, 2015 04:52 PM
srobert910
Oct 4, 2002 05:39 AM
dvlad
Sep 30, 2002 12:10 PM
nwind21
Aug 27, 2002 10:00 PM
