VQ35DER 240Z Build (W/ Pics)
Old Dec 13, 2008 | 08:21 AM
  #61
irax's Avatar
irax
so what's the fuel pressure to be set at with fuel return?
Old Dec 14, 2008 | 08:59 PM
  #62
EmWhyr0hEn's Avatar
EmWhyr0hEn
Thanks for the comments guys.
I'm rumming the 6-speed w/ a 4.11 welded diff to be exact. Should be a lot of fun. I'm currently trying to get my driveshaft worked out but, once thats done I'll have some driving vids posted.
I'm running my fuel pressure with the stock settings of 52psi w/o the vacume line attached.
Old Dec 14, 2008 | 11:39 PM
  #63
irax's Avatar
irax
so you think a walbro 255 pump should be good enough? or my factory 195 pump?
Old Dec 15, 2008 | 09:38 AM
  #64
copec's Avatar
copec
I know Z1 motorsports is using all the stock fuel system for their 320whp car...
Old Dec 15, 2008 | 10:10 AM
  #65
irax's Avatar
irax
ohh, i should if specified. I am swapping in a VQ35DE into my 240sx and want to utilize the stock fuel return system. Thats why I asked what the fuel pressure would be set at in fuel return mode VS returnless fuel setup. And if the factor ~195LPH would be enough or should I upgrade to a 255LPH ?
Old Dec 15, 2008 | 10:16 AM
  #66
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Z1 Performance
if stock pump is 195 lph that's bigger than a stock Z, so should be more than fine
stock fuel pressure on a Z is around 53.5 IIRC
Old Dec 15, 2008 | 12:12 PM
  #67
copec's Avatar
copec
Originally Posted by Z1 Performance
Z1 Performance
sorry! my bad!
Old Dec 17, 2008 | 09:55 AM
  #68
EmWhyr0hEn's Avatar
EmWhyr0hEn
I'm using a Walbro 255 which is good for gobs of power. Overkill if you ask me. You should be fine with what you have if your just going to run a stock engine.
Old Dec 30, 2008 | 04:13 PM
  #69
EmWhyr0hEn's Avatar
EmWhyr0hEn
I have a short low quality vid. More to come later.
This is with a Borla 3'' XR-1 round, and a 4.11 rear end. I start in 2nd gear only going 1/2 throttle!
http://www.youtube.com/watch?v=l6RsTrMgz3c
Old Dec 30, 2008 | 05:13 PM
  #70
OCG35's Avatar
OCG35
^^^ prob with the vid link again...
You might consider photobucket, then linking here.
Old Dec 31, 2008 | 03:57 PM
  #71
EmWhyr0hEn's Avatar
EmWhyr0hEn
Fixed the problem. Sorry! I really need to check after....
Old Dec 31, 2008 | 04:03 PM
  #72
SlideFox's Avatar
SlideFox
You got some pretty cool vids on youtube.... need more pics!!!!!!!
Old Dec 31, 2008 | 06:45 PM
  #73
OCG35's Avatar
OCG35
F-ing nice!!!! rpms climb REALLY fast on throttle... that thing will be a beast on the track!
* note to self = unsubscribe to thread - or get a dedicated track car! *
Old Jan 2, 2009 | 02:35 PM
  #74
EmWhyr0hEn's Avatar
EmWhyr0hEn
Thanks guys.
I'm curently changing out my rear end out for a 3.54 because the 4.11 were waaaaay to short and I wasnt able to put the power down when exiting corners. It was pretty rediculous I was shifting gears all the time and I could accelerate in 6th fairly quickly lol.
Here are some finishing pics.
Old Jan 2, 2009 | 02:37 PM
  #75
SlideFox's Avatar
SlideFox
Looks sick!!!
Old Jan 2, 2009 | 06:08 PM
  #76
35oZephyR's Avatar
35oZephyR
wow... i want that.
Old Jan 3, 2009 | 09:43 AM
  #77
thekinn's Avatar
thekinn
Nice! Thanks for sharing your project here. Very nice work, clean.. Sexy.
Old Dec 9, 2011 | 01:56 AM
  #78
KingBaby's Avatar
KingBaby
Hardest Setting
bring it back...
<-----looking for something to replace my 240sx void...
Old Dec 9, 2011 | 12:00 PM
  #79
Classy's Avatar
Classy
I would definitely go with a different swap for that car! In fact, I would never swap in a vq into another car, so much money for not much of a return
Old Dec 9, 2011 | 03:57 PM
  #80
snobes's Avatar
snobes
that car is so much WIN!
