rebuilding motor
Old Aug 26, 2009 | 07:39 AM
Reality350's Avatar
Reality350
Originally Posted by scotts300
Why does your 04' have an OC problem is my question. . .
Originally Posted by gabe3d
^^yeah, I have the same question. The OC problem is only apparent on revup engines.
He would not be the first, with a Non Revup DE motor, to experience OC.. A close friend had the same problem with his '04.5..
OP, have you read the PCV thread? its a $20 part that may help you (only if your warranty is denied)
GL
Old Aug 26, 2009 | 10:48 AM
scotts300's Avatar
scotts300
I have seen/heard/read about very few non-revup cars with OC problems, and all those cars were running synthetic oil.
OP - is this with synthetic oil?
Old Sep 2, 2009 | 02:27 PM
MDeezy's Avatar
MDeezy
I've heard rebuilding and using 07 altima piston rings have solved the problem for them
Old Oct 4, 2009 | 10:21 AM
Raginraj11's Avatar
Raginraj11
GL
I havent read the PCV thread. I will look into it though.
Yup synthetic oil.
Old Oct 4, 2009 | 07:47 PM
Raginraj11's Avatar
Raginraj11
I was just wondering what are the chances that built motors can also have catastrophic oil consumption problems? Is the OC chance moderately reduced since the forged internals are stronger? As far as i know the design flaw in these motors is with the piston rings which causes the major OC, so replacing the stock internals with forged internals should prevent this problem from reoccurring correct?
Old Oct 5, 2009 | 04:33 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
The fact that an aftermarket piston or rod is forged has nothing to do with oil consumption. Oil consumption is the result of clearances within the engine which are set by the person who puts the engine together.
Old Oct 25, 2009 | 07:01 PM
xdragus's Avatar
xdragus
GL
Looks like OP and I are in the same boat and looking at a similar course of action to fixing our engines.
350Z_Al
Oct 29, 2020 07:44 PM
