Crazy Plenum Update - More Sillyness Finding Power
Old Jan 24, 2010 | 08:46 PM
  #61
INTIMAZY's Avatar
INTIMAZY
Originally Posted by gabe3d
I am pretty sure Sasha is using a Motec 800 to control it.
Yea I saw that part. I was hoping the ECU can run the GM TBs. I don't know what the Nissan pinouts are on the 70mm TBs. A google search says the 90mm LS2 pinouts are as follows....
PIN ID LS2 90mm
A.) ACT2
B.) ACT1
C.) +5v TPS Reference
D.) TP1 Signal 0-5v
E.) Common Ground
F.) TP2 Signal 5-0v
stolen from corvetteforum.com
Any idea on the compatibility between these and the Nissan ECU would be? Doesn't look like we would even need to use all of these pins...
Old Jan 24, 2010 | 09:26 PM
  #62
Nexx's Avatar
Nexx
hrmm.. maybe HR wont be that much faster with the right plenum...
Old Jan 24, 2010 | 09:31 PM
  #63
kacz07's Avatar
kacz07
DE>HR
DE>VHR
Old Jan 24, 2010 | 09:42 PM
  #64
Nexx's Avatar
Nexx
Originally Posted by kacz07
DE>HR
DE>VHR
Old Jan 25, 2010 | 04:00 AM
  #65
mw9's Avatar
mw9
Nice work as always. Keep us updated.
Old Jan 25, 2010 | 04:39 AM
  #66
rcdash's Avatar
rcdash
If you flow bench each individual runner (i.e. put a MAF over each outlet and measure) you will find discrepancies in the stock setup because of the momentum of the air as it comes around the neck. An off center baffle that recognizes this disparity and equalizes mass air to each bank may help you pull out a few more ponies.
I look forward to seeing how you can model the open air test into practical form. I would think you would need an rpm window switch operated valve right at the plenum itself. Not easy...
Nice work and good luck!
Old Jan 25, 2010 | 07:23 AM
  #67
Zazz93's Avatar
Zazz93
To address the previous comment, SG do you plan to rework the lower collector (other than the Rev-up ver.) i.e. MREV or custom?
Old Jan 26, 2010 | 07:07 AM
  #68
SGSash's Avatar
SGSash
Vendor - Former Vendor
Thanks for all the comments guys! It's a lot of fun trying to make more power and its very satisfying to see that the community is as interested in the progress as we are. Of course the videos help share the experience.
The stock non-revup intake is really quite good, 285ft lbs of torque out of a stock 3.5L engine is pretty up there! However I think the intake is running out of steam above 7000rpm and it will need to be changed when we start running the engine out to 8000+, but until I test different cams + compression I won't know for sure so that's just my best guess right now.
I would like to again try the revup plenum and see if it's starting to out flow the non-revup at high rpm or not, and see how bad the mid-range losses are.
I'll keep you all up to date!
Old Jan 26, 2010 | 09:55 AM
  #69
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Right on Sasha! That's real R&D work!
Old Jan 26, 2010 | 03:37 PM
  #70
chinabean's Avatar
chinabean
interstangg
Old Jan 27, 2010 | 03:45 AM
  #71
PlatinumSR20's Avatar
PlatinumSR20
PIN ID LS2 90mm
A.) ACT2
B.) ACT1
D.) TP1 Signal 0-5v
E.) Common Ground
F.) TP2 Signal 5-0v
or maybe swapping out the factory pedal for a LS2 throttle pedal also...
Old Jan 27, 2010 | 03:52 AM
  #72
SGSash's Avatar
SGSash
I'm in the process of trying to make the GM TB work with the roadster's stock ECU now, or perhaps flashed with UpRev.
Even if it worked I would reccomend it ONLY for off-road use, this isn't the kind of stuff you want going wrong in traffic!!
I'll keep you guys updated
Old Jan 27, 2010 | 04:13 AM
  #73
INTIMAZY's Avatar
INTIMAZY
But of course! Just about all the Z parts are "offroad use only" anyway. We wouldn't dream of running catless or running alternate fuel management on the street, right?
Old Feb 1, 2010 | 12:22 AM
  #74
_ink's Avatar
_ink
Pure Awesomeness!!!
Cannot wait for more updates!
Old Feb 1, 2010 | 04:32 AM
  #75
PlatinumSR20
lol...
Old Feb 1, 2010 | 04:40 AM
  #76
3FIDDYZED's Avatar
3FIDDYZED
Just out of interest as I couldnt see it in the thread (it may be in another one!) what ecu you running and also whats it tuned with?
How many pulls you running on the dyno after changing configs?
Old Feb 1, 2010 | 06:56 AM
  #77
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Motec M800
Old Feb 1, 2010 | 08:37 AM
  #78
3FIDDYZED's Avatar
3FIDDYZED
Originally Posted by Z1 Performance
Motec M800
Cheer Adam, just realised its at the top of this page! myself!
Old Mar 4, 2010 | 02:45 PM
  #79
SGSash's Avatar
SGSash
Ok guys, I have some good news, and a lot of bad news.
Number one, the stock ECU with a Haltech standalone (I have one of those for the roadster too!) running MAP sensor was able to work with the GM throttle body. HOWEVER, it would throw a code every time the engine was started as it detected a throttle fault, and the code would have to be cleared to take the DBW out of failsafe mode. Once that was cleared, we dyno'd with the Carbotron plenum and 90mm throttle body.
So with the SGM headers we had re-baselined the car at 284whp, up 5whp from the previous tests mostly due to an improved header design and a bit more power from the UpRev flash (rather than just the Pulstar plugs). I copied over the int cam / exh cam / ignition timing that I was running with the UpRev, and quickly tuned the Haltech to run in the high 12s / low 13s. Once the thing was tuned I did a few pulls, and to my amazement, there was no power gain! 283-286whp.
Stock cats/manifolds to SG headers:
Headers to Intake + TB:
The conclusions are hard to pull from this test, but one would imagine it comes back to the cams, as that's the main difference here between the racecar and the roadster.
Old Mar 4, 2010 | 02:49 PM
  #80
Z1 Performance
Former Sponsor
Sasha if you have access to Osirus you can flash the ecu to ignore that code. That's what I did with my current setup (cable throttle)
