Problems : ReVup Cams on DE cams
Old Feb 23, 2010 | 02:26 PM
NiZMo1o1's Avatar
NiZMo1o1
Default Problems : ReVup Cams on DE cams
Alright so im at the shop and I pull off the cam sprockets off the DE Cams
I notice that the bolt on the DE cams (bolts) are shorter than the RevUp cams (bolts) Exhuast side
Ive install the dowel pin and sprocket but the DE bolt is too short and wont even thread in.
The RevUp bolt is longer and leaves about half of inch (hand tight)
is there something else im missing here ? do I need spacers ?
A buddy of mine said his was straight forward , re-use the DE bolt into the Cams.
im 100% sure these are RevUp cams , but could there be differnt years ? or am I missing something ?
I search and search but not quite seeing what im looking for and im a limited internet connection right now.
Need some quick answer from some experenice guys or whomever.
Thank you
Old Feb 23, 2010 | 04:32 PM
NiZMo1o1's Avatar
NiZMo1o1
not one person knows ?
This is the Revup bolt , theres alot of slack ..
Old Feb 25, 2010 | 08:07 AM
NiZMo1o1's Avatar
NiZMo1o1
well you ****ers werent much of a help , close thread.
already resolved it by getting a grade 10 bolt
Old Feb 27, 2010 | 02:24 PM
SexyRob's Avatar
SexyRob
how could you expect a revup (with a special exhaust cam magnet retarding system) to use the same bolt as a non-rev with just a plain gear?
pretty sure a new bolt is the only method.
Uriyo_
Sep 8, 2021 08:46 AM
