View Poll Results: Going from 2in exhaust,to a 3in, longtube header, 2.25 Ypipe,on 8000K ITB Rev make?
1-5WHP
12.66%
5-10WHP
17
21.52%
10-15WHP
13
16.46%
15-20WHP
20
25.32%
20-30WHP
19
24.05%
Voters: 79. You may not vote on this poll
Kevin's VQ35DE NA Build Epilogue..
Old Oct 30, 2010 | 11:27 PM
  #121
MIKERNM1990's Avatar
MIKERNM1990
Old Oct 31, 2010 | 05:53 AM
  #122
kgkeen101's Avatar
kgkeen101
Originally Posted by MIKERNM1990
this thread said that JWT Camshaft C-2 on 315 WHP?
Yes car made 315NA on the C2 now we're on a bigger cam. It was also 55* temp on the shop dyno which is outside. The most recent videos was 88* weather and at that 300whp. Once it cools down and the tunes done should be above the 315 just from the bigger cams of course.
Old Oct 31, 2010 | 06:31 AM
  #123
tuko316's Avatar
tuko316
Did your builder mention anything about the headers? Did he say they will be fine for a big cam? Not worried about a bottleneck?
Old Oct 31, 2010 | 09:05 AM
  #124
MIKERNM1990
Old Oct 31, 2010 | 03:00 PM
  #125
kgkeen101's Avatar
kgkeen101
The temperature outside is the variable on the dyno right now because its that much more humid and hot out vs our dynos on the C2 cam, thats all.
Old Nov 1, 2010 | 11:54 PM
  #126
MIKERNM1990
Old Nov 2, 2010 | 05:02 AM
  #127
kgkeen101's Avatar
kgkeen101
yeah hope to wants its done and tuned I'll post updates =)
Old Nov 4, 2010 | 05:25 PM
  #128
kgkeen101's Avatar
kgkeen101
New setup, ProEFI Flex Fuel E85. Got everything going on the new cams, tuned. Got a throttle position sensor this time, didn't have one prior. Just some updates it's really cool equipment.
Old Nov 4, 2010 | 05:26 PM
  #129
kgkeen101's Avatar
kgkeen101
Putting down about 310whp in the heat. When it cools down 325 seems reasonable for the temperature difference. Solid NA power.
Old Nov 5, 2010 | 02:01 PM
  #130
tuko316's Avatar
tuko316
How does the power band compare to before? Not a big increase in peak power with bigger cams and exhaust.
Old Nov 5, 2010 | 02:43 PM
  #131
kgkeen101's Avatar
kgkeen101
The peak power didn't increase more than 10 to 15whp. But power under the curve at around 7600 is another 30whp higher than the c2s or so. We are going to try and dyno in the same cool weather we had on the c2s. Its down to around 55 degrees or so with the outdoor dyno just like when we hit 315na. Ill show the graphs and you can compare other na graphs power drops at 7600 vs 6300 or so. Main thing is the intake combo. Exhaust just carried power even further out under the curve.
Old Nov 5, 2010 | 02:50 PM
  #132
tuko316's Avatar
tuko316
Why go through the trouble of dynoing in colder weather? Can't you just switch the graph to corrected #'s? 30whp is a nice improvement even if its not peak.
Old Nov 5, 2010 | 06:23 PM
  #133
kgkeen101's Avatar
kgkeen101
Yes I agree if I only had the corrected numbers. They didn't save in the computer at TPS. This time I will save both corrected and uncorrected. That's the only reason why id do it hehe. Its all good its always fun watchin her on the dyno
Old Nov 11, 2010 | 09:00 AM
  #134
NiZMo1o1's Avatar
NiZMo1o1
Kevin , perfect time now to dyno , lovely boost weather !
Old Nov 16, 2010 | 06:22 AM
  #135
kacz07's Avatar
kacz07
Dynos or !!!
Old Nov 16, 2010 | 06:47 AM
  #136
kgkeen101's Avatar
kgkeen101
Originally Posted by kacz07
Dynos or !!!
Hehe well I have the car in my possession again. So I'd have to bring it to a shop to dyno it again.
Old Feb 17, 2012 | 10:03 AM
  #137
kacz07's Avatar
kacz07
Bump?
Old Feb 28, 2012 | 07:37 AM
  #138
NiZMo1o1's Avatar
NiZMo1o1
Bump?
spoke to kev over the weekend, he is finishing up college/studies
I believe after he is done he will jump back onto this.
Old Oct 11, 2013 | 02:48 PM
  #139
zswickliffe's Avatar
zswickliffe
I'm gonna take the chance to bump this as well. Maybe he's back on it?
Old Oct 12, 2013 | 11:11 AM
  #140
WTFMike's Avatar
WTFMike
I believe he parted it out awhile ago. I bought his flex-fuel setup.
