Cams for 06 NA stroker build
Old Feb 7, 2011 | 05:51 PM
e30cabrio's Avatar
e30cabrio
Default Cams for 06 NA stroker build
I'm having a hell of a time picking cams. The car is a daily, I want the idle to be relatively smooth. I want as much out of it as possible within reason.
Motor has Injen Cai, Motordyne MREV2, 5/16th spacer, Headers ARTs, XYZ with resonator, Agency Power Ti cat back, UPREV tune.
Build consists of 88mm Brian Crower crank BC Econo rods, JE 96.5mm 11.0.1 pistons +1mm Manley valves.
I have not bought the cams or springs yet I need help deciding on them.
Old Feb 7, 2011 | 09:00 PM
KA24DE's Avatar
KA24DE
I would have skipped the stroker and just put a good set of JWT cams in.
Old Feb 7, 2011 | 09:23 PM
e30cabrio's Avatar
e30cabrio
The reason for the build is oil consumption.
Old Feb 9, 2011 | 06:33 AM
e30cabrio's Avatar
e30cabrio
It is interesting. I was told angrily when I complained about a seller that misrepresented a part that did not fit I should have posted a thread and the answer would be posted "immediately"
It has been days and I only have an answer to a question I did not ask.
Looks like JWT C8 are the way to go. Anybody care to verify/refute that conclusion?
Old Feb 9, 2011 | 05:49 PM
Sparks03Max's Avatar
Sparks03Max
With the stroker setup, those C8s should be perfect for good power without losing streetability. BC3s would be a little more mild, but also a good choice.
Old Feb 10, 2011 | 04:01 AM
e30cabrio's Avatar
e30cabrio
Thanks
350Z_Al
Oct 29, 2020 07:44 PM
