the_coupe's NA build cp manley bc
Old Sep 2, 2011 | 03:00 PM
  #541
the_coupe's Avatar
the_coupe
ive got it listed everywhere.....been so for the past 2-3 weeks. couple bites from cl but nothing. guess nobody has that kinda money for a car ATM cuz my dealer is sellin a few used auto coupes for 17-20k alone.
i'll end up putting my stock motor back in unless someone wants it bone stock with a built motor lol
Old Sep 2, 2011 | 03:59 PM
  #542
Classy's Avatar
Classy
I just went through your part out thread, why don't I see anything I want!!!
Old Sep 2, 2011 | 04:01 PM
  #543
e30cabrio's Avatar
e30cabrio
Originally Posted by the_coupe
ive got it listed everywhere.....been so for the past 2-3 weeks. couple bites from cl but nothing. guess nobody has that kinda money for a car ATM cuz my dealer is sellin a few used auto coupes for 17-10k alone.
Sorry.
Because you HAVE everything?
Do you have a wideband AFR?
Old Sep 2, 2011 | 04:51 PM
  #544
the_coupe's Avatar
the_coupe
lol sucks cuz i got alot of goods too.
and i just sold my aem twin channel w/b a couple hours ago!
Old Sep 2, 2011 | 04:59 PM
  #545
e30cabrio's Avatar
e30cabrio
dammit!
Old Sep 2, 2011 | 05:57 PM
  #546
mgrotel's Avatar
mgrotel
I need an oil cooler if you have one
Old Sep 2, 2011 | 06:39 PM
  #547
the_coupe's Avatar
the_coupe
nope no oil cooler. lol
Old Sep 2, 2011 | 06:55 PM
  #548
e30cabrio's Avatar
e30cabrio
eBay. The SETRAB I got was 100 shipped.
Old Sep 3, 2011 | 07:50 AM
  #549
mgrotel's Avatar
mgrotel
I'll check it out, thanks. Does it have a connector to hook up a oil temp gauge?
Old Sep 3, 2011 | 07:59 AM
  #550
e30cabrio's Avatar
e30cabrio
No, that would go on the sandwich plate that goes under the oil filter.
Old Sep 3, 2011 | 08:00 AM
  #551
Classy's Avatar
Classy
I don't really care about widebands with an N/A daily drive set up, if I go any more extreeme with my set up, I will run them, but for now, why?
I don't have everything! I need a better radiator setup, short shifter and ****, oil cooler eventually, and I really want to go with probably a 3.9 gear ratio and a OS Giken 1.5 way rear diff (but that last part is $$$)
Old Sep 3, 2011 | 08:02 AM
  #552
e30cabrio's Avatar
e30cabrio
I want the wideband to know I am not going to blow up the motor. I had one in my Acura CLs that was totaled. I emailed the guy I sold it to that parted it out and he still has it so we'll see what he wants for it.
I have the 4.083 final & Quaife. Love is too weak to express how much I like them!
Old Sep 3, 2011 | 08:44 AM
  #553
Classy's Avatar
Classy
How much of a difference did they make, and there is no way to recalibrate the speedometer is there
Old Sep 3, 2011 | 08:51 AM
  #554
e30cabrio's Avatar
e30cabrio
Huge difference. Speedo is 4mph high but I use my NAV to keep track of my speed so don't care.
Old Sep 3, 2011 | 10:07 AM
  #555
mgrotel's Avatar
mgrotel
your speedo was prob that far off before, cause the car detects speed by the sensors at both half shafts AFTER the differential. so no gear change will affect the speedo. and if it did, it would affect it on a percentage basis, not mph basis. what i mean by that is you may be 4mph off at 60mph, but at 30mph, you will only be 2mph off. but the gears will not affect the speedo. i will be getting gears, just want to see where my peak hp is first. if its the same as now, might just do 3.7s
and if you are going to be osiris tuned, you can monitor a/f with that, so no real need for a wideband unless you want it displayed all the time as you drive. i have one, but mainly to monitor for lean spots with spray
Old Sep 3, 2011 | 10:13 AM
  #556
e30cabrio's Avatar
e30cabrio
It must be the 265 35 18s then. I have osiris, how can I display AF through it?
Old Sep 3, 2011 | 10:41 AM
  #557
0jiggy0's Avatar
0jiggy0
Read the manual? Use the cipher gauges and click the checkbox next to air/fuel ratio.
And gears do not affect speedo. It's your rims and tires.
Old Sep 3, 2011 | 10:46 AM
  #558
e30cabrio's Avatar
e30cabrio
I had the car tuned and don't have a tuner license.
I don't want to read the value on my laptop while I drive hence the statement I want a gauge.
Thanks for the RTFM response you were hepful.
Old Sep 3, 2011 | 03:32 PM
  #559
mgrotel's Avatar
mgrotel
If your tuned then your a/f ratios should be fine, as long as you have faith in your tuner. Do you have an Osiris cable? I don't see the need to be watching a/f constantly other than some might think it looks cool. So, checking them on the laptop every so often for peace of mind should be more than enough
Old Sep 3, 2011 | 03:33 PM
  #560
mgrotel's Avatar
mgrotel
Wait, what year is your car? If I remember right, some of the older models had narrow band O2s instead of widebands
