my turn
Old Jul 21, 2011 | 11:22 PM
mgrotel's Avatar
mgrotel
Default my turn
vq non rev
96mm cosworth 11:1 forged pistons
eagle Hbeam forged rods
ARP main studs
HR head gaskets and head bolts
ACL race series bearings
BC stage 2 cams
ferrea 6000 series stock sized valves
supertech dual valve springs
MD 1/2" plen spacer
worked nonrev lower plen
worked upper plen, specifically gasket matched to the tb
nismo Rtune headers
megan v2 test pipes (considering getting different ones)
MD resonated xyz Ypipe
DMH electronic cutout
stock midpipe and muffler
mishimoto radiator
edge racing 3200 stall torque converter (im auto)
revup oil pump
ATI dampner pulley
pathfinder cooling mod
water jackets machined
rotating assembly balanced
headwork by headgames
OEM injectors cleaned
headers and tp jet hot coated
all intake pieces gasket matched
polished crank
i think that about covers it
will get a tune and then depending on where my peak power is will get either 3.7, 3.9, or 4.08 final drive gear ratio.
Old Jul 22, 2011 | 01:11 AM
Mcutali's Avatar
Mcutali
Originally Posted by mgrotel
has that water jacket been opened up? if so howd u do that? water jet?
Old Jul 22, 2011 | 07:25 AM
mgrotel's Avatar
mgrotel
just had the machine shop do it while they had the block
Old Jul 22, 2011 | 09:45 AM
mgrotel's Avatar
mgrotel
Old Jul 22, 2011 | 10:08 AM
lgear080's Avatar
lgear080
that looks pretty... good luck w your project!
Old Jul 22, 2011 | 01:04 PM
mgrotel's Avatar
mgrotel
thanks!
Old Jul 22, 2011 | 03:55 PM
the_coupe's Avatar
the_coupe
lemme guess......wiseco pistons, eagle rods, bc 264s?
*your motor has a boner teehee
Old Jul 22, 2011 | 04:01 PM
mgrotel's Avatar
mgrotel
almost, cosworth pistons, but 11:1 nonetheless ha
Old Jul 22, 2011 | 04:38 PM
mgrotel's Avatar
mgrotel
Old Jul 22, 2011 | 04:42 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
When you get done with piks please post full parts list thx
Old Jul 22, 2011 | 05:33 PM
mgrotel's Avatar
mgrotel
edited first post
Old Jul 22, 2011 | 05:59 PM
the_coupe's Avatar
the_coupe
ahh now you add pix! lol the pistons look hella diff from my CPs......atleast they were smart and put an arrow on them! can you take a pic of both sides of the piston skirt for me??
Old Jul 22, 2011 | 06:06 PM
mgrotel's Avatar
mgrotel
I'll see if I have one already, but pistons are in the block as of now. Pretty sure there is a set of 11:1 cosworths in the classified section, he might be able to take pics for you
Old Jul 22, 2011 | 06:13 PM
mgrotel's Avatar
mgrotel
This is the best I have
Old Jul 22, 2011 | 06:25 PM
the_coupe's Avatar
the_coupe
well, not much of a skirt to it lol....im just curious as to how the side notched for the squirters is compared to the opposite side.
Old Jul 22, 2011 | 08:01 PM
2004Black350z
Exhaust Whore
I would highly rec dumping the megan test pipes. Im not going to say ART pipes though lol. I dont believe they have had great success with aftermarket headers. I say maybe find some 2.5" test pipes.
Old Jul 23, 2011 | 06:17 AM
mgrotel's Avatar
mgrotel
You know of a specific brand to recommend?
Rtune header primaries are stepped, so my thinking is that it wouldn't hurt to have the entire exh get gradually bigger at each component as well
Old Jul 24, 2011 | 09:50 AM
mgrotel's Avatar
mgrotel
Old Jul 24, 2011 | 04:48 PM
kacz07's Avatar
kacz07
I want Headgames to port and polish my Cosworth. They're only about 30 mins from me. If you're in the area, you're more than welcome to come check out my car.
Have you dropped off your heads yet? How do you like them? Heard great things.
Old Jul 24, 2011 | 06:28 PM
mgrotel's Avatar
mgrotel
Wish I was in the area, I woulda saved a ton on shipping and it would be cool to see your car, but I'm in Utah, damn elevation! Lol
