HR buckets
Old Oct 19, 2011 | 06:49 AM
mgrotel's Avatar
mgrotel
Originally Posted by pchio
Will that also be the reason why HR engines run a lot hotter than DE?? Just wondering...
less friction would mean less heat buildup in the engine, and also less energy lost making heat. so i would think the opposite would be true
Old Oct 19, 2011 | 07:03 AM
denchan350gt's Avatar
denchan350gt
Originally Posted by djamps
Why are you tuning it twice?
Tune for the cams (which is needed) install the LTH sameday and if needed tweak my tune depends on what Vince says or does.
Old Oct 19, 2011 | 08:58 AM
mgrotel's Avatar
mgrotel
why doesnt nissan use roller bearing lifters/buckets like other newer engines? that would keep friction to its minimum. is there just not enough room in there?
Old Dec 13, 2011 | 04:23 PM
Torgus's Avatar
Torgus
Any updates?
Old Dec 13, 2011 | 05:21 PM
Classy's Avatar
Classy
I am just going to put it out there, unless you are actually pulling the cams out (HUGE job) this is not something that serious, I didn't use them personally, but I am sure they will make alittle something, but unless I was getting new springs/retainers in and bigger cams, I would leave good enough along, there are better areas to spend money on the car.
Old Jan 21, 2012 | 04:32 PM
rich2342's Avatar
rich2342
What were the result O.P.?
Old Mar 5, 2012 | 01:54 PM
Torgus's Avatar
Torgus
Courtesy Nissan online sells the buckets for only like $18 bucks new. Definitively going in on my head build next year.
Old Mar 5, 2012 | 03:23 PM
denchan350gt
make sure that you get the right sizes after you measure for clearance.
HoBrahYouStink
Jun 24, 2016 10:58 PM
sentry65
Oct 2, 2005 10:36 AM
Brad4rdHay
Oct 23, 2002 07:07 AM
