Tomei 272 Cams + after market pistons.
Old May 23, 2014 | 03:27 AM
Glover41's Avatar
Glover41
Default Tomei 272 Cams + after market pistons.
Hi there ..
What CR pistons do you guys recommend with Tomei's in&ex 272 Cams ?
I'm between 11.5 and 12.0 ?!
95 pump gas here ..
Engine: VQ35HR
Pistons i'm considering: CP pistons.
Car running with Headers and CAI.
Thank you ..
Old May 23, 2014 | 05:15 AM
Glover41's Avatar
Glover41
Up..
Old May 23, 2014 | 02:54 PM
Glover41's Avatar
Glover41
Hey anyone ?
Im about to place an order for the pistons but first need to determine their CR.
awaiting for ur help ..
Old May 23, 2014 | 10:03 PM
Glover41's Avatar
Glover41
Where are the experts ?
Old May 25, 2014 | 08:33 AM
Zazz93's Avatar
Zazz93
I'm at 11.0 with Weisco's...no complaints with my Tomei 272's.
Old Jun 3, 2014 | 04:29 AM
Csomme's Avatar
Csomme
I am at the same, 11.0 with my 272s. No complaints. Could go higher, but would need to run something with higher octane.
Old Feb 25, 2015 | 08:43 PM
The_Assassin's Avatar
The_Assassin
What gains did you guys see by going 11 comp
Old Mar 5, 2015 | 01:33 PM
Zazz93's Avatar
Zazz93
Can't say... I'd have to see a dyno of both setups to know. I did it because, in general, its a complimentary add on for the rest of the package.
Old Mar 5, 2015 | 03:38 PM
The_Assassin
oh ok, thought you would have tested it on the track or dyno.
Old Mar 28, 2015 | 09:59 PM
Frostydc4's Avatar
Frostydc4
vq35hr?
Old Apr 3, 2015 | 11:52 AM
Zazz93's Avatar
Zazz93
Yeah... its not really practical to do that type of test. It involves around 20 hours of labor and the expected gains are not massive. So, for those of us who are in the engine... and have the money... its just something you do if you think its worthwhile for your needs. I was in a position where I needed new pistons and had done a lot of other complimentary mods so I spent a little more and added high comp. pistons.
After everything said and done, I'd think twice about it now... I had issues with a light piston slap at cold engine temps. Forged pistons don't act the same as cast pistons when it comes to expanding and contracting with heat. It was likely more of a problem with my machinist (opening up a bore too much) but its not ideal for a DD.
Old Apr 3, 2015 | 07:18 PM
rich2342's Avatar
rich2342
What is your set up? Do you have any clips?
Old Apr 6, 2015 | 04:01 PM
Zazz93's Avatar
Zazz93
Sorry no clips, and the setup is in my profile's "Garage". https://my350z.com/g/album/2564668#
dcains
Nov 11, 2015 11:36 PM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
