N/A Build 350z 2004 Non rev up
Old 09-14-2016, 02:18 PM
ScubaSteveZ33
ScubaSteveZ33's Avatar
Default N/A Build 350z 2004 Non rev up
Hi I am new to the forum and this is my first post. I have a 2004 350z base model with the following mods.
AAM plenum spacer
Volant Intake
STILLEN oil cooler
Straightpiped from the cat back.
My upcoming mods will be berk test pipes along with dc ceramic headers.
Im looking for feedback/tips for making more power but also maintaing reliability.
Im looking into getting the MREV2 along with the 75mm nwp throttle body.
Old 09-14-2016, 07:00 PM
Conway_160
Conway_160's Avatar
Myrev2 doesnt do anything for a non revup. Just get your plenum spacer and port and polish your lower plenum
Old 09-14-2016, 10:32 PM
ScubaSteveZ33
After further research I saw that the non rev up motors already come with the MREV 2. As for the porting and polishing of the lower plenum, i dont think i will be going that route just yet.
Instead of buying the MREV2 im am now looking into buying an AAM y pipe.
Old 09-16-2016, 07:31 AM
BluestreamDE
BluestreamDE's Avatar
Remember to Get tuned by a reputable dyno shop with experience in Nissan/Infiniti and UpRev Osiris after u install all your parts, assuming you would use UpRev as your reflash software as it is the cheaper alternative from using a standalone.
Old 09-16-2016, 07:44 AM
ScubaSteveZ33
I was thinking about buying Osiris 's Standard package and having it tuned by them. Theres only 1 tuner for vq motors out here in socal with a good reputation but his prices are insane.. sadly. Will I need a tune after the headers and test pipes?
Old 09-16-2016, 09:08 AM
BluestreamDE
Yes, you need to tune with any part you add onto your car. You will more than likely be running lean AFRs which is dangerous for ur motor especially at WOT. A small fix to this is to unplug your battery and reset the ECU overnight so it is forced to do its fuel learning tables, but by doing this, the stock ECU can only compensate fuel soo far to a point when a retune is needed.
ScubaSteveZ33 (09-16-2016)
Old 09-16-2016, 01:37 PM
ScubaSteveZ33
The shop installing my headers is about 30-40 mins away, will I be fine driving back after the installation? I will be installing the test pipes myself, but hopefully i can get the shop to just install the test pipes free of charge since they are already down there.
Old 09-16-2016, 06:58 PM
BluestreamDE
You will be fine under normal operation without going wide open throttle.
Old 09-17-2016, 10:38 AM
seymore4
Professional
seymore4's Avatar
The tune makes a big difference, just removing the factory throttle restriction makes it a lot more responsive
Old 09-19-2016, 06:25 PM
ScubaSteveZ33
Heres an update, just got my berk test pipes and Dc sports ceramic headers and this is what they look like together.
Old 09-20-2016, 10:50 AM
BluestreamDE
Looking good, my only concern would be your straightpipe setup giving you more rasp and rattlecan sound/note with no exhaust restrictions. Some like the sound of it, some don't.
Also consider a lightweight flywheel like JWT for better throttle response, faster revs and acceleration. Final drive gearing also helps with acceleration, I had a 3.91 final drive with my Nismo flywheel, full boltons and tune before I went boost and I loved it.
Old 09-21-2016, 08:44 PM
slicnicz33
slicnicz33's Avatar
There are 3 solid places for tunes for your DE in SoCal ,
Church automotive (Orange County )
Specialty Z ( northern LA area / SF valley)
Pismo Knights tuner ( Central LA area)
Plenum spacer , headers, test pipes, then Osiris tune your Z and you should be happy with the results.
I would go with a stiffer clutch and lighter flywheel first and wouldn't touch the diff final drive if the Z is your DD , weekend car and your staying n/a then go nuts
Fair warning the test pipes make your Z insanely raspy and loud over 4.5k good luck in SoCal my friend
Old 09-22-2016, 04:34 AM
travlee
Master
travlee's Avatar
Received 9,049 Likes on 6,515 Posts
my thinking, him being in commi-fornia, knowing he wont pass smog it might be a track toy
Old 12-11-2016, 05:37 AM
Stichie Stich
Stichie Stich's Avatar
If it helps any, I know I'm a little late, but I installed myself ngk double platinums, dragon force cops, true duals cat back, plenum spacer, cold air, oil cooler, trans cooler and synthetic everything on my Enthusiast with NO tune and she still doesn't hAve an SES light or any issues. She will tear that vls down the streets and is more responsive than ever. But I haven't tuned her yet and she is a monster
Old 12-11-2016, 05:39 AM
travlee
Master
travlee's Avatar
cool story
The following 2 users liked this post by travlee:
BluestreamDE (12-11-2016), vegasanthony (03-09-2017)
Old 03-13-2017, 12:14 PM
ScubaSteveZ33
Yeah I am thinking of putting a resonator just to be safe. Since my last post I have purchased an AEM digital afr, Megan racing v2 y pipe, and im in the process of buying my nwp throttle body. My question is, after all these mods and a tune will I atleast be near or in the 300 club? I know its really hard for DE's with non built motors to break the 300 mark. Im only asking because Im having a freindly competition with my buddys Mazda Speed 3.
Old 03-13-2017, 12:19 PM
ScubaSteveZ33
Tell me about it, Number 1 reason Id like to go live in another state.
travlee
Master
travlee's Avatar
no.
Old 03-13-2017, 12:25 PM
travlee
Master
travlee's Avatar
my friend with an 03, almost all the same mods as you hit 255whp on a mustang... if you add 11% or so which they are supposed to be lower than dynojet will put you at 283 ish on a good day... now if you went hub dyno, which usually read higher side, it may be close.
Old 03-13-2017, 12:29 PM
ScubaSteveZ33
no.
Intresting, Thank you for the straight answer haha. Ill have the car dynoed when everything is done and let you guys know what the car put down.
Quick Reply: N/A Build 350z 2004 Non rev up
