350z rpm delay
Old May 6, 2018 | 03:31 PM
KingZ33's Avatar
KingZ33
Default 350z rpm delay
I have a 05 AT 350z and recently tapping the gas pedal and the car lunges a little. Although every now and then the car rpm just shoots up and doesnt go no where. Im scared of a transmission issue.
also i have an 04 z and it seemed a lot faster than my 05 both stock besides pod filter.
Old May 7, 2018 | 06:53 AM
Atreyu'z 350's Avatar
Atreyu'z 350
So your question is what? Why does your Z not move sometimes when you step on the gas while you're in DRIVE? Or the rpm's just shoot up while the car's in neutral and the rpm's stay there? And you want to know why your '04 Z is quicker than your '05 Z?... Is your '04 Z an automatic as well? How many miles are on both cars?
Old May 7, 2018 | 07:24 AM
KingZ33's Avatar
KingZ33
Ok my 05 i tap the gas while in drive and sometimes the rpm shoots up but the car does not lunge. Sometimes when i give it gas it takes a second or too for it to take off. I was thinking my transmission is slipping?
My 04 was also AT with 150k. My 05 is AT with almost 130k. Both stock. Only difference is my 05 has an wing when i purchased it.
Old May 7, 2018 | 08:11 AM
BluestreamDE's Avatar
BluestreamDE
Go to a shop to diagnose. No way were gonna figure out what's wrong with the vague amount of info you typed here. You gave no codes either.
Old May 7, 2018 | 08:43 AM
Atreyu'z 350
I would think one of three things..
- Low transmission fluid: You won't develop enough hydraulic pressure for proper clutch and torque converter engagement. Check the level and condition of your fluid.
- Failing torque converter: Low fluid will result in excess heat and can damage the TC and clutches if left unchanged. If this is what's wrong, more fluid won't help. A replacement TC will be needed.
- Worn out clutches/bands: Low fluid reduces hydraulic pressure, which will cause the clutches to slip, and if left unchanged will cause them to burn/wear out. More fluid won't help. A replacement clutch pack will then be needed.
Old May 7, 2018 | 12:52 PM
KingZ33's Avatar
KingZ33
Thanks ill check the fluid.! And hopefully the TC is still good. Fingers crossed. 😰
Old May 8, 2018 | 03:33 PM
KingZ33's Avatar
KingZ33
Default Muffler
Sorry one more question. I took my muffler off niw its just cats no resonator. No muffler. Will there be enough back pressure or is it going to bliw the motor eventually?
Old May 8, 2018 | 04:00 PM
Atreyu'z 350
Hahaha.. No you're fine man. But why'd you do that?
Old May 8, 2018 | 05:17 PM
KingZ33's Avatar
KingZ33
Sounds like a formula 1 car when u get on it.
Old May 9, 2018 | 05:21 AM
Atreyu'z 350
Oh, ok.
Old May 9, 2018 | 07:05 AM
Heel Til I Die's Avatar
Heel Til I Die
Old Aug 31, 2020 | 12:35 AM
Joey.z33's Avatar
Joey.z33
Quick question do you drive in auto or the manual mode? Cause if your driving in auto your transmission is not slipping it has sensors that keeps the car from red lining itself if you drive in manual mode you have more control over that so when u press the gas you should immediately takeoff... just know when to shift, if it’s not that then maybe we had a similar problem and my car was jerking and I would tap on the gas and go nowhere so I found out my transmission was loose and I got a new transmission mount and that fixed the problem
Old May 4, 2021 | 02:31 AM
mdlwate357's Avatar
mdlwate357
OP, any updates? My 05 AT touring coupe is doing the same thing.... if I floor it in Drive the rpms shoot up like it's in neutral. If im cruising at 55mph and then floor it, the rpms shoot up but it takes a fee seconds for car to take off. However, if I just take off like normal and drive with the flow of traffic everything seems fine...no slipping. Car definitely seems slow...
Cannysage
Dec 4, 2008 08:13 PM
LovemyG
Aug 15, 2004 11:59 AM
sirius
May 17, 2004 12:03 PM
