Jenvey ITB Drive By Wire + airbox
Old Nov 1, 2023 | 06:52 AM
Diren's Avatar
Diren
Default Jenvey ITB Drive By Wire + airbox
Hi,
Anyone got a drive by wire setup working with a Jenvey ITB setup?
The Jenvey Actuator has failed twice in my setup.
Also, anyone got an airbox solution that works with the curved horns?
Regards,
Diren
Old Nov 2, 2023 | 05:10 AM
iideadeyeii's Avatar
iideadeyeii
Look into someone who can CAD/3dprint. I've made custom horns for a motorcycle which gained 13% horsepower over stock, I'm assuming something could be done with wither a 2-piece box which slips over the rear of the horns and sandwiches on the lip to make a box
or a complete redesign of the horns to taper to run a cone filter off each.
Lastly and easiest would be to run some sort of custom ~45ppi oiled sock that would cover each horn individually with some sort of metal grate to prevent it from getting sucked in.
As far as the actuator could you incorporate the stock actuator to open the butterfly's?
Destram
Dec 19, 2010 11:13 PM
ag0240
Jul 2, 2009 08:17 PM
viper54
Aug 16, 2006 05:48 PM
UrbanTacticZ
Apr 9, 2006 03:48 PM
sponsorsthisway
Sep 26, 2004 05:28 PM
