"Hacking" The AVH-P6800DVD to Play DVD's While Driving
Old Aug 10, 2006 | 05:21 PM
viper54's Avatar
viper54
Default "Hacking" The AVH-P6800DVD to Play DVD's While Driving
Alright Guys,
As you know I installed the p6800dvd last week and figured out how to hack it if some of you do not know.
Here is how:
Alright, first take off the dash/ or whatever to get close to the parking break. There will be a olive(light green) wire running to the ebrake. Cut some plastic off from the middle of the wire (keep it attatched to the EBRAKE). Now, get a 2 Prong Toggle switch at your local Autozone. Attatch a wire from the olive ebrake wire to one of the prongs to the toggle switch, and then gound out the other wire. Now you are set. If you have any questions, post em.
Old Aug 10, 2006 | 07:22 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
i just put it on a switch, one side to the parking brake wire, the other side to ground, when you normally drive and start hte car, leave it off, when you want to watch, flick the switch
b
Old Aug 11, 2006 | 09:43 AM
bbhiznors's Avatar
bbhiznors
i know this is a little off topic but does any one know how to get new back grounds (when the music is playing) for this player...i hope that makes sense hah
Old Aug 15, 2006 | 10:56 PM
viper54's Avatar
viper54
Would love to know also.
Old Aug 16, 2006 | 05:26 AM
Alberto's Avatar
Alberto
Cranky FI Owner
+1 on backgrounds. I took 16psi's advice and put it on a switch...
Old Aug 16, 2006 | 08:29 AM
VO...'s Avatar
VO...
Administrator
why not just ground the wire to the chasis? This worked for me..
Old Aug 16, 2006 | 08:34 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
grounding it to a chasis wont work...
when the unit starts up, it cannot see a ground signal, or it wont bypass, it first have to see NO ground signal and then ground signal for it to bypass...not sure how it worked for you but all the 6800s i have done, this is not the case
b
Old Aug 16, 2006 | 08:42 AM
Ichigo's Avatar
Ichigo
You have to burn your JPG's to a cdr and browse the cdr from the deck. If you have a cd in there already, you must remove it to load the CDR with the jpg's. To my knowledge, even with an AVIC Z-1 (built in HDD) you cannot store anything but the 2 selected backgrounds (one for AV and one for Nav) on the unit. Any additional backgrounds will need to come from the disk.
Old Aug 16, 2006 | 05:48 PM
bdmpastx's Avatar
bdmpastx
go to www.avic411.com they have a lot of info there.
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
Mattg350z
Oct 2, 2015 06:51 AM
