Quick question...
Old May 27, 2011 | 02:29 PM
Cole_S's Avatar
Cole_S
Default Quick question...
I am looking to become a soon-to-be Z owner, but first I've got to get through the search process Anyways, I am going to look at one tomorrow
Specs:
'05 - Black
82,500 miles
K&N CAI
14" touch screen nav/radio
Asking price - $13,500 (I plan on offering $11,500 )
Whatever, to my question. Is there anything specific to look for/at tomorrow? Rust spots, (un)known squeaks/rattles, etc., just list them up.
Thank a lot!
Old May 27, 2011 | 04:01 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Have a mechanic check it out. They will know how to look at the car as a whole and tell you if anything looks questionable.
I'm no mechanic, but at a minimum (and off the top of my head), I would look at:
- tire wear patterns
- belts
- fluids
- brakes
- signs of oil at seals/gaskets/upper collector/spark plugs
- body condition
- body lines (indication of repairs)
- paint match/blends (indication of repairs)
- proper alignment
- bushings
- make sure that the tranny feels smooth and consistent
- listen to the engine at idle and under various loads and rpms
- get some miles on the car with a long test drive, pushing it hard and also driving at cruise for extended periods and check for codes with an ODBII scanner
- See what the engine computer shows for average MPG and pay attention to how long it has been recording (the longer the better as proof the owner isn't hiding anything)
- Have a shop change the oil and oil filter and tell you what they both look like
You're looking for evidence of either meticulous maintenance, average maintenance, poor maintenance, or damage/problems. All of this factors into the value/condition of the car. Again, best bet is have a mechanic do a full inspection for you. The best insurance policy you can buy before you drop a bunch of money on a car.
Old May 27, 2011 | 04:08 PM
SparkleCityHop
Living in 350Z
Oh, yeah. And make sure that everything works.
- Windows roll up and down with no problems
- All lights work
- All switches work
- A/C blows cold, heat blows hot
- Wipers work on each setting and delay works
- Cruise control works
- Seat heaters work
- Seat adjustments work
- 12V DC outlets work
- Dome/Interior lights work
- Speakers work
- Mirror adjustment works
In other words, if there is a button/****, make sure that it works. If you don't know what it does, check the owner's manual, then make sure that it works.
Old May 28, 2011 | 12:37 PM
Cole_S's Avatar
Cole_S
Right, all the basic stuff to look for. What I'm more trying to ask is, are there anything specific to the Z that I need to look out for. Example, areas that are prone to rush, parts on the engine that should be replaced because they've reached a certain mileage, etc.
Old May 28, 2011 | 12:48 PM
2005 is known for transmission problems. There are better choices: https://my350z.com/forum/2009-370z/5...ts-smacks.html
Old May 28, 2011 | 04:29 PM
SparkleCityHop
Living in 350Z
Sorry, didn't know what level of experience/knowledge you had with cars based on your original post.
Tranny and window motors are definitely suspect/repeat issues for that year. Bad paint. Easy damage to door handle area in hot/humid conditions (the coating becomes gummy and is easily damaged). Those are the items that I know about because I have a 2004.5 model.
It would be a good idea to check the TSB's for the particular year that you're considering.
Old May 28, 2011 | 05:35 PM
angelo350z's Avatar
angelo350z
With used cars comes used problems, so I'm sure you're ready. All I'd really care about is oil consumption, prior body damage/repair, and overall driveability problems such as grinding noises, loss of power, interior switches not working, etc.
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
Paul.
Oct 16, 2015 07:34 PM
