Need help choosing a 350z
Old Aug 6, 2017 | 11:56 AM
Valid Username's Avatar
Valid Username
Default Need help choosing a 350z
I want to buy a 350z but I'm not really sure which one I should buy... I am not a car guy at all I mean besides knowing the most basic stuff, everyone recommends a 350z for me and after seeing it for a while its the first real car I actually like and I can afford, the problem lies in which one I should buy I don't know the difference between gran touring, touring, enthusiast, roaster and such. This will be my everyday car (my first car) so I was wondering if anyone could tell me which one would best fit for just everyday driving (I'm from Miami if that changes anything) this car will most likely never see a track either so if you guys could inform me on which one best fits me I would appreciate it
Old Aug 6, 2017 | 12:05 PM
dcains's Avatar
dcains
Read the FAQ. The link is above. Learn to search - every possible question has already been answered.
Old Aug 7, 2017 | 03:22 AM
travlee's Avatar
travlee
Master
a honda
Old Aug 7, 2017 | 04:40 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Welcome.. What's your budget?
Old Aug 7, 2017 | 04:43 AM
travlee's Avatar
travlee
Master
Originally Posted by Atreyu'z 350
Welcome.. What's your parents budget?
fixt
Old Aug 7, 2017 | 04:49 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Personally, I like the roaster model. Comes in handy around Thanksgiving. After doing up the bird, one can take it out on Dugan Hwy for a spirited run.
Sorry.
OK, pulled this old thing out and don't recall exactly what years this covers.... I think just the early models up to '05. You can easily look up the GT and Nismos to get the full pic.
Z33 MODEL IDENTIFICATION
BASE MODEL
6-Speed MT Only - $26,269
Longitudinally-Mounted 3.5L 24-Valve DOHC VQ35DE V6 engine producing 280+ horsepower and 260+ lb/ft of torque
Drive-By-Wire Throttle
High Flow Intake System
Continuously Variable Valve Timing (CVTCS)
Micro-Finished Crankshaft and Camshafts
Molybdenum Coated Pistons
Sequential Multi-Port Electronic Fuel Injection
Nissan Direct Ignition System (NDIS)
Transmission
6-speed close-ratio manual transmission
Short Throw Linkage
Drivetrain
Mid Mounted Front Engine/Rear Wheel Drive
52/48 Front/Rear weight balance
Carbon-Fiber Driveshaft
Braking System
Power-Assisted 11.65" Vented Front Disc Brakes & 11.5" Vented Rear Discs
Anti-Lock Braking System (4-wheel ABS) w/ Brake Assist
Electronic Brake Force Distribution (EBD)
Suspension/Chassis
Unibody Construction with Corrosion Resistant High Strength Steel
Lightweight Aluminum Hood
Power-Assisted Engine-Speed-Sensitive Rack-and-Pinion Steering (15.9:1
steering ratio)
4-wheel fully independent Multi-Link suspension
Lightweight Aluminum-Alloy suspension components (suspension arms, entire rear subframe, etc)
Front and Rear Stabilizer Bars
Rear Strut Tower Brace
Aerodynamics
Low coefficient of drag with under car air management system
Flat underbody design with deflector and diffuser plates
Exterior
Aluminum-Look Door Handles
Full Body Color Mirrors and Bumpers
Flush-Mounted Headlights
Dual Outlet Exhaust
High Output, Flush Mounted Halogen Lighting System
17" X 7.5" 7-Spoke Aluminum-Alloy Wheels
P225/50WR17 Front & P235/50WR17 Rear High Performance Michelin Tires
Comfort and Convenience
Tilt Steering Column and Integrated 3-Bay Instrument Gauge Cluster
Automatic Temperature Control System
3-Guage Cluster with Oil Pressure, Voltmeter and Trip Computer
Power Windows, Locks and Mirrors
Remote Keyless Entry System
Variable Intermittent Front Windshield Wipers
Rear Intermittent Wiper
Overhead Sunglasses Storage Compartment
Electric Rear Window Defroster
Leather Steering Wheel & Shifter
Aluminum Interior Accents
6-Way Manual Adjustable Driver’s Seat
160-Watt AM/FM/CD w/6 Speakers
Safety and Security
Dual Stage Supplemental Air Bags
Vehicle Security System
Seat Belts w/Pre-Tensioners & Load Limiters
Nissan Vehicle Immobilizer System
___________________________________
ENTHUSIAST
6-Speed MT - $28,249
5-Speed AT - $29,219
Includes Standard Equipment Plus:
Xenon 4-Bulb High Intensity Discharge Headlights
Traction Control System (TCS)
Viscous Limited Slip Differential (LSD)
Cruise Control
Homelink Universal Transceiver
Aluminum Pedals
Day/Night Automatic Rear View Mirror
Dual Illuminated Vanity Mirrors
Optional:
5-speed Electronically Controlled Automatic Transmission with Manual Shift Mode
PERFORMANCE
6-Speed MT Only - $30,429
Vehicle Dynamic Control (VDC)
18" X 8" 6-Spoke Aluminum-Alloy Wheels
P225/45WR18 Front & P245/45WR18 Rear High Performance Michelin Tires
Tire Air Pressure Monitor
Cruise Control
Aluminum Pedals
TOURING
6-Speed MT - $33,179
5-Speed AT - $31,589
Touring Models w/5-Speed Automatic Transmission:
Bose 7-Speaker 240-watt Audio System w/ In-Dash 6-Disc CD Changer, AM/FM Stereo and Cassette Player
Leather-appointed Seats
Power 4-way Driver’s Seat
Power 2-way Passenger Seat
Heated Seats
Heated Mirrors
Cruise Control
Aluminum Pedals
Touring Models w/6-Speed Manual Transmission Additionally Include:
TRACK MODEL
6-Speed MT Only - $34,079
Brembo Brakes with 4-Piston Front Calipers, 2-Piston Rear Calipers
Front 12.75" Vented Front Discs and 12.67" Vented Rear Discs
18" X 8" 6-Spoke Super Light Forged-Aluminum Alloy Wheels by Rays
"Zero Lift" Package for high speed stability including:
-Rear Drag Reducing Spoiler
-Front Spoiler
Cruise Control
Aluminum Pedals
Old Aug 7, 2017 | 04:50 AM
travlee's Avatar
travlee
Master
Old Aug 7, 2017 | 04:51 AM
MicVelo's Avatar
Originally Posted by travlee
Eh, whatever... copy n' paste because I'm in a good mood.
Oh yeah, I'm in a decent mood because of your stupid pun about the HONDA being best FIT. Ar ar. Groan.....
Old Aug 7, 2017 | 04:55 AM
travlee's Avatar
travlee
Master
Old Aug 7, 2017 | 07:27 AM
Atreyu'z 350
a 2008 Honda S2000
fixt
Old Aug 7, 2017 | 07:36 AM
Atreyu'z 350
Sorry.
BASE MODEL
Transmission
Short Throw Linkage
Drivetrain
Braking System
Suspension/Chassis
steering ratio)
Aerodynamics
Exterior
Dual Outlet Exhaust
Safety and Security
ENTHUSIAST
Cruise Control
Aluminum Pedals
Optional:
PERFORMANCE
Cruise Control
Aluminum Pedals
TOURING
Heated Seats
Heated Mirrors
Cruise Control
Aluminum Pedals
TRACK MODEL
-Front Spoiler
Cruise Control
Aluminum Pedals
OP will need an Advil after this..
Old Aug 7, 2017 | 07:50 AM
MicVelo's Avatar
What, you don't appreciate the time I took to type that up when the CTRL-C - CTRL-V failed on my cornpooter?
Hmmmph, he'd need a valium if I bothered with the GT and Nismo models along with the changes after '05!
Old Aug 7, 2017 | 08:12 AM
Atreyu'z 350
