Cam sensor problem
Old Oct 20, 2019 | 03:50 PM
James Sheehan's Avatar
James Sheehan
Default Cam sensor problem
Replaced bank 1 and 2 cam sensors and its and it's still throwing a code anyone else have this problem if so how do I fix
Old Oct 20, 2019 | 05:52 PM
travlee's Avatar
travlee
Master
Did you use oem sensors.....if not, that is your issue
Old Oct 20, 2019 | 06:24 PM
James Sheehan
Default Cam sensor issues
I used duralast sensors
I heard I should be using Hitachi is this true
Old Oct 20, 2019 | 11:17 PM
bealljk's Avatar
bealljk
yes ...
replace your crankshaft position sensor too ...
what issues are you having?
Old Oct 21, 2019 | 04:07 AM
James Sheehan
I did not do the crank shaft sensor
I was told there were two crank shaft sensors is this true?
Old Oct 21, 2019 | 06:27 AM
MotaBike Mike's Avatar
MotaBike Mike
Only one crankshaft position sensor. Should be mounted back on the right side of the bell housing. If it's the same as the HR cars you can get to it from under the car, you have to sorta do it by feel, but its doable.
jdr63420
Jul 21, 2014 07:07 PM
blazin202
Jun 25, 2014 04:09 PM
JoeZee
Nov 6, 2013 03:24 PM
arc2010
Jun 3, 2013 03:16 AM
marco485
Mar 24, 2012 02:57 PM
