No heat from AC
Task completed
-Coolant flush completed
-Filled until bleeder
Symptoms
-115 to 95 Degrees Celsius on warm up idle.
Is this due to the Heater core & Thermostat?
Doubt it would be clogged, any advice? Been trying to remove air lock & bubble’s but no solution. Would turn off without an engine code when running idle, recorded temp mentioned above before turning itself off. Bleeder valve opened at idle with no coolant to show, only when filling coolant will be seen overflowing through bleeder.
Please help with suggestions! Don’t want to blow up my VQ35DE
Symptoms
