TPMS sensors.
Old Feb 25, 2008 | 05:13 PM
ZRA's Avatar
ZRA
Default TPMS sensors.
According to my TPMS readout on the dash, the front tire readout with the lower arrow pointing to the left read 5 pounds lower then the rest of the tires. I figured that this tire was in the front driver's side. I measured the two front tires and they both read 37 PSI. I then measured the rear two. The rear right tire read 32 PSI. I inflated it to 37 PSI. Went down the road and all tires read 37 PSI. Question: Is it possible to get the TPMS sensor circuits mixed up?
Old Aug 10, 2008 | 08:35 AM
tlichten's Avatar
tlichten
Only if you change the tires/rims. The TPMS are individually coded and setup at the factory, so the Left-Front sensor is programmed and the Left-Front readout on your dash, RF is RF, etc. Difficult thing though is that the stock rims are different sizes, so unless the tire shop moved the TPMS to the wrong wheel when you got those new rims....?
Old Aug 11, 2008 | 12:41 PM
ZRA's Avatar
ZRA
My dealer re-programmed the sensors. Now they're right. thanks.
kyin
Oct 15, 2015 05:54 AM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
commasense
Sep 30, 2004 01:06 PM
