Click or Pop from clutch?
Old Jul 29, 2008 | 01:11 PM
only350z's Avatar
only350z
Default Click or Pop from clutch?
Does anyone else have this issue?
It doesn't bother me that much but I don't want to have problems later.
After the clutch is depressed and you are releasing, it "clicks" or "pop" from around the pedal? My 05 Accord also had this strange noise.
I saw from a post that someone recommended using WD-40 around the pedal/clutch?
Any advice is great!
Sam
Old Jul 29, 2008 | 02:27 PM
Zultimate's Avatar
Zultimate
Sam
Just purchased an 06 and noticed that it does this sometimes - kinda annoying.
Old Jul 30, 2008 | 05:36 AM
Lento's Avatar
Lento
Yea that happens to mine, its usually when im in traffic or trying to shift at really low RPMs, or backing out or pulling into a parking spot.
I'm pretty sure its normal... (I hope)
Old Jul 30, 2008 | 06:03 AM
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
Yep, same here...it's fcking annoying (to me) but there's nothing wrong with my clutch, which is a good thing.
Old Jul 30, 2008 | 06:28 AM
drivesolo's Avatar
drivesolo
It's been happening to mine for about a 2 months now. It's starting to get on my nerves. I'm debating if I should take it to the dealership or try to trouble shoot this myself.
Old Jul 30, 2008 | 08:36 AM
Lento's Avatar
Lento
If it isn't creating any real problem, leave it alone. If you want to take it to the dealer I am sure they can create one for you
In all seriousness, your best bet may be to call them up and tell them what is going on, and possibly bring it in and show them yourself. Maybe they have come across it before and just tell you Yay or Nay on a fix. But I wouldn't want them pulling my car apart to fix the problem, because that means they will have to put it back together.
From personal experience when someone has to put something back together, it always involves a new scratch or something on my car that pisses me off for months.
Old Jul 30, 2008 | 08:38 AM
savvy's Avatar
savvy
mine does this also, 05 base model. Started doing it a couple months ago. Have about 30k on the clock.
Old Jul 30, 2008 | 09:07 AM
only350z's Avatar
only350z
I'm thinking about going in and only showing them the issue but not let them touch my freaking car. Just to see what kind of lame excuse they are going to give me. I can easily produce this noise weather the car is off or on, all I have to do is depress the clutch and release it and "clunk" or "pop".
My question is, do you think this will cause a problem in the future?
I can live with the abnormal "cluck" or "pop" as long as the car is going to run fine...
Sam
Old Jul 30, 2008 | 09:21 AM
drivesolo's Avatar
drivesolo
I had an S13 years ago and it had the same problem, more prononced though. Not only could you hear it you could just feel it on the bottom of your foot. Turned out that a plastic bushing that held an assist spring had broken apart and was making the noise. Only pieces of the bushing was left just slidding around in the hole making all sorts of we're popping and crackling noises when the clutch pedal was depressed. I removed the assist spring all together and just drove it w/ ther heavier clutch pedal force.
Old Aug 1, 2008 | 08:27 AM
DEN350Z's Avatar
DEN350Z
i have a 07 that did the same thing it started about 1 month after slave cylinder recall took it back to dealer they said that the clutch master cylinder was building up to much pressure so when you released the pedal it would pop they replaced the cluth master cylinder popping is gone.
Old Aug 1, 2008 | 08:41 AM
drivesolo's Avatar
drivesolo
Mines is an '07 too and started to make that noise soon after I brought it in for the recall.
Old Aug 3, 2008 | 10:52 PM
Spyris's Avatar
Spyris
I have the same issue. I'm going to bring it in this Wednesday. We'll see what the dealer does.
Old Aug 6, 2008 | 05:28 PM
fordslowcus's Avatar
fordslowcus
Just started noticing this last night when backing up, then again when i rolled forward. The sound went away but It might be because of the engine noise/wind drowned out the noise. 06 @ 35k miles. I should check if theres any recalls on this for 06.
Old Aug 24, 2008 | 05:13 PM
bijan z's Avatar
bijan z
06 base - does it too......only when its in gear and releasing it....if its in neutral its quiet.
Old Aug 24, 2008 | 05:40 PM
Spork's Avatar
Spork
It's normal drivetrain noise for the Z.
Old Aug 27, 2008 | 12:07 PM
eddie3782's Avatar
eddie3782
Anybody know a fix for this yet?
Old Aug 27, 2008 | 12:14 PM
jelly's Avatar
jelly
my 06 started to make the noise after about a year of driving. i took it into the stealership to check it out (since it was still well under warranty), and they seemed to have fixed it. the tech mentioned that some metal wire(?) was abrasing against the clutch pedal lever or something. anyways, the noise was gone for a while, but it came back after about 6 months again. now, i'm just driving it around...
i went to Connell Nissan in Costa Mesa, just in case if you were wondering.
good luck.
Old Jun 14, 2009 | 06:50 AM
garu's Avatar
garu
Sorry to bring back the old thread alive.
But I noticed my 06 doing the same thing. The clutch always 'clicks' when engaging the gas pedal as I let it go.
My car has less than 25000 miles.
Should I take it to the dealer?
Old Jun 14, 2009 | 06:54 AM
only350z's Avatar
only350z
Haha. Never made it to the dealership...
Still makes the "click/clunk" noise when I release the clutch but no problems yet...
Old Jun 14, 2009 | 10:01 PM
kennylin888's Avatar
kennylin888
So you mean that they just replaced the clutch master cylinder and that annoying noise was gone? Isn't this the problem with the bearing or something? Mine has about 4.5k miles now and started to hear this noise about 2 months ago. Is really annoying but really can't find any solution to this problem here in the forum. I will record the sound and post it later...
