How much would HKS Hipermax III drop?
Old Jan 15, 2009 | 10:15 PM
godlike0104's Avatar
godlike0104
Default How much would HKS Hipermax III drop?
How much would HKS Hipermax III drop with 19x9.5/19x10.5 volk wheels/stock wheels??
Please help
Old Jan 16, 2009 | 12:09 AM
nismoZomsin's Avatar
nismoZomsin
i can show you how much the HKS hipermaxIII's will drop my Z on 19 inch volks tomorrow...after i get it readjusted/aligned.
Old Jan 16, 2009 | 03:31 AM
Ataru074's Avatar
Ataru074
enough to put your stock wheel inside the fender (if you max out the drop)
Old Jan 16, 2009 | 07:21 AM
xBey's Avatar
xBey
new owner here planning very similar set up with HKS Hypermax and 19's...can i see too (pics that is)...???
Old Jan 16, 2009 | 11:38 AM
nismoZomsin
<a href="http://imageshack.us"><img src="http://img211.imageshack.us/img211/7606/adj3vk6.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a>
the rear is maxed out, the front has some play left. both front and rear have not settled since the install, so it will be much lower later. hope this helps
–oh btw, these are the sports.
Old Jan 17, 2009 | 01:10 AM
godlike0104
So i guess fender rolling is a must?? Is the height of the ride adjustable ?
Old Jan 17, 2009 | 05:47 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
that's the purpose of coilovers...they give you adjustable height
Old Jan 17, 2009 | 10:10 AM
nismoZomsin
i'd definitely recommend rolling and possibly pulling as well. my first setup was with HKS RSII's and well though it didn't tuck the wheels, daily driving scored lines into the rear tires before rolling/pulling.
—i'm not sure if it makes much of a difference but, with the RSII's i was running on 245's in the front and 275's in rear without rolling and it rarely rubbed, but now i'm at 255 front, 285 rears after rolling/pulling and since then no rub, even on hard U-turns or the occasional unknown pothole
Old Jan 19, 2009 | 09:01 AM
Gsedan35's Avatar
Gsedan35
NismoZomsin, can you take a picture of the model label on the side of one of your HKS dampers? HKS has never made a RSII that I have ever seen.
HKS RS coilover
Mildly valved
spring rates 448/448
HKS II coilover
Aggressively valved
spring rates 504/504
RS has now been replaced by the HKS III
II has now been replaced by the HKS Sport
Old Jan 19, 2009 | 09:10 AM
Gsedan35's Avatar
Gsedan35
Please help
Ran a search,...........
Originally Posted by Gsedan35
HKS III (Monotube construction, adjustable damping, full length height adjustment separate from spring preload
Spring rates 504/504
Min and Max ride height Front: 0 to -1.6” Rear: 0 to -1.9”
HKS III Sport (Monotube conscrution, adjustable damping, sport valving, full length height adjustment separate from spring preload
Spring rates 616/672
Min and Max ride height Front: 0 to -1.7” Rear: 0 to -1.4”
Of course I'm too lazy to figure out how much shorter or taller your listed tire and wheel sizes are vs oem.
Old Jan 19, 2009 | 09:09 PM
nismoZomsin
HKS RS coilover
Mildly valved
HKS II coilover
Aggressively valved
mmm youre right! they were the RS's. i've been through many setups and well now i got the III sports, i really dont care to remember the old ones. thanks for pointing that out
–BUT my new HKS box label says theyre Hipermax III Sport.
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
