Tires advice?
Old Apr 7, 2009 | 07:23 AM
only350z's Avatar
only350z
Default Tires advice?
Post this else where but didn't really get much help.
Maybe my fellow NISMO brethrens can help me.... PLEASE.
I currently have TE-37s, 19x9.5 +22 (F) / 19x10.5 +22 (R).
These are the tires I want to get.
Michelin PS2
Fronts 265/35/19
Rears 285/30/19
I really don't want to roll the fenders or have any rubbing issues but want to go widest possible.
Any advice on the tires itself or specs. is appreciated.
Sam
Old Apr 7, 2009 | 08:19 AM
only350z's Avatar
only350z
You guys suck.
Old Apr 7, 2009 | 07:46 PM
nismofreak1208's Avatar
nismofreak1208
i was thinking about getting the ps2's also, i've heard on other forums (not z's) that they are pretty good for wat they are compared to its competitors, i believe it went against the bridgestone re05s and goodyear f1's and a dunlop tire, but i forgot which one, and the ps2's came out on top over all, i might get them but like u, i'm waiting for some z owners to test 'em out, if not i'ma stick bridgestone and go re-11's
Old Apr 7, 2009 | 10:31 PM
s2k2nismo's Avatar
s2k2nismo
i run 265/35/19 and 285/35/19 same rim and tire......no rubbing and i am lowered
Old Apr 8, 2009 | 08:09 AM
Nizmo0395's Avatar
Nizmo0395
i went with a different wheel 95 cobra r 17x9 with faulken aziens 615 270/40.
mostly for tire rotation and a different look. when i push the car around a turn the front end pushes a little.cost 140 per tire and not a lot of drop of in performance unless you push hard in the corners.thats my 2 cents.
Old Apr 8, 2009 | 08:10 AM
only350z's Avatar
only350z
You sir are the BEST~!
Thank you for your time in giving me some decent advice.
1 more question.
If I run 265/30/19 in the rears, do you think they will be any issues or do you recommend 265/35/19??
Sam
Old Apr 8, 2009 | 08:11 AM
only350z's Avatar
only350z
Those are the 2 tires I am currently stuck with.
RE-11s or PS2s.........!
I've been thinking and I might go with the RE-11s just so I can save some cash and get some SS lines and new cross-slotted rotors.
Old Apr 8, 2009 | 09:38 AM
Sensi09's Avatar
Sensi09
Works Concepts
I have the RE-11s on the stock wheels, but not sure they offer the right sizes for your TEs. What sizes are you thinking about with the RE-11s?
Old Apr 8, 2009 | 05:33 PM
dbsears's Avatar
dbsears
I think 255/40/18 and 275/35/19 would be perfect for the RE-11 on stock wheels. They don't offer 275/35 though in the US...they do though in Japan. I have been wondering how hard it would be to get a set here...
Old Apr 8, 2009 | 09:33 PM
Sensi09's Avatar
Sensi09
Works Concepts
^Yeah those are the sizes I would probably run if they were offered. Instead, I ordered 265/35/18s and 265/35/19s in the RE-11s. I think in past threads, I said I would rather go wider with a different tire, but honestly compound is more important than width. Oh and I really wanted to try the RE-11s.
Old Apr 9, 2009 | 01:05 AM
dbsears's Avatar
dbsears
I have also thought about 275/30/19 and 255/35/18. Those are currently offered in RE11. They maintain the front to rear diameter difference as OEM but they are just .7in shorter in diameter. Not a big deal I don't think seeing as the stock Z already has way too tall of gearing.
ablaine
Nov 29, 2016 10:13 AM
