What kind of Coilovers are you guys running for AutoX and Track
Old May 11, 2009 | 12:34 PM
MillhizzelPB's Avatar
MillhizzelPB
Default What kind of Coilovers are you guys running for AutoX and Track
I am having a hard time picking the one to go w/. No one really has anything bad to say about any of them. I have narrowed it down to Stance AL+pro or Tein Monoflex. What do you guys think. If there is somthing way better let me know. I want to use the car mainly for AutoX and Track, but i will be driving it on the street from time to time.
Thanks
Old May 11, 2009 | 12:36 PM
NISMO_558's Avatar
NISMO_558
Whats your budget?
HKS hypermax III seem to be popular.
Old May 11, 2009 | 12:57 PM
Ataru074's Avatar
Ataru074
hypermax III sport here.
good to begin with. good car balance with a stiff diff in the rear...
BUT.. if I'll do it again, I'll go for koni truechoice double adjustable. (is "a little" more expensive, but I think could make the difference)
Old May 11, 2009 | 02:23 PM
importdemon5's Avatar
importdemon5
Zeal function X coilovers these are rated up there with the DG5. The DG5s are roughly $5k (aka breaking the bank), the zeal functions are about $3k.
You can get either of these coilovers in 12k front and 10k rear spring rates.
Old May 11, 2009 | 04:50 PM
MillhizzelPB
what makes the Zeal better then the DG5, MonoFlex or Stance al+ Pro?
thanks
Old May 12, 2009 | 04:51 AM
Lento's Avatar
Lento
Whats wrong with the stock ones?
Old May 12, 2009 | 05:57 AM
MillhizzelPB
It feels like the valving is not quick enough. The car doesn't get settled fast. when the back end kicks out u have to slow down for the suspension to settle. The suspension should do that for you w/ some compensation from the wheel. i want to be able to adjust the rebound and dampening.
Old May 12, 2009 | 08:20 AM
Lento's Avatar
Lento
^Ah I see, that makes sense. It seems you know what your talking about. I was skeptical because I believed a lot of people got coilovers just to add another mod to their list, and I didn't see the point of it until what you just discribed.
Old May 12, 2009 | 10:19 AM
MillhizzelPB
any one have any brands that the really stand behind? as of late i have been leaning towards stance but i am open to whatever.
Lento dont get me wrong the stock is good i just want a little bit more for the track and auto X =)
Old May 12, 2009 | 12:50 PM
Lakeside's Avatar
Lakeside
Are you looking for street comfort as well as track performance?
I have the HKS Hypermax III's. Ataru074 has the sport version. Which is stiffer.
I don't have any complaints with the HKS setup. I need to tweak it alittle more. The car has yet to see a track. But it gets thrown down some agressive mountain roads.
Plan to take it in and have the wheel weight balanced, camber and toe tweaked while its there to be Tuned. The car needs it.
Old May 12, 2009 | 02:10 PM
Jacob350z's Avatar
Jacob350z
id say stance and tein are two popular brands
i myself have a set of stance gr+pros about to come in and i will autox on those =)
Old May 12, 2009 | 03:55 PM
importdemon5
I've just heard things about both. I've heard that the DG5s are better but the Zeals are rated up there with them. I'm planning on getting the Zeal x coilovers after summer.
Old May 12, 2009 | 04:00 PM
MikeC350z's Avatar
MikeC350z
I plan on getting the Tanabe Sustec Pro SEVEN with the TEAS system. It can be set to adjust at specific speed intervals plus the convenience of the control switches from the driver's seat is a big plus.
Old May 13, 2009 | 03:11 AM
Ataru074's Avatar
Ataru074
you know which is the bad part?
that what feels incredibly crisp on the road is going to be "sloppy" on the track...
the biggest limitation that I found in hypermax sport is that the bounce and rebound rate feels "good" but not "right"...
I still feel that have too much bounce control against the rebound
don't get me wrong... you can go damn fast with those suspension without having the "stock nismo feeling" of the car disconnected from the tarmac when you push to the limit....
I can't even go close to the new limit without leaving a massive skidmark in my pants... but... I still don't have the "right" feeling that I had on a full race setup.
Old May 13, 2009 | 04:46 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
i have KW v2 installed on my car and have done serveral autox and hpde events, i love my setup and they feel great around the track and are good enough to drive around in too.
Old May 13, 2009 | 06:44 AM
MillhizzelPB
zpaaji do you like the KW? are there anythings that you dont like about the KW?
Old May 13, 2009 | 08:05 AM
JDSMotoring
I do like the KW's, for the money i belive they're a great buy and work excllent on the track. Its the only set of coilovers i've had on my car so I can't really compare them to any other set out there.
Old May 13, 2009 | 08:34 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
first, set yourself a total budget
as Ataru correctly mentioned (he does quite a bit of track work) the setup one runs on the street is a far cry from what one tends to run on the track - I don't care how aggresive you think you drive it on the street, or how much you attack the mountain roads, the entire dynamics are vastly different. It takes quite alot of dialing in to get a car that truly will do double duty with little to no adjustments
Given your uses, neither of your possible choices would even be on my list of worthy considerations. Which would be? Again, depends on your budget (don't forget the ancillary parts needed to truly get it setup properly), your tire selection, and your actual skill level in terms of suspension adjustments
Old May 13, 2009 | 09:29 AM
MillhizzelPB
Z1 What would you get if you you were me. I am open to anything, even going w/ diffrent tires if that would really help. my budget on the suspension would be 1-2k. i know that i would also need front and rear camb kits.
Thanks
Old May 13, 2009 | 09:46 AM
Z1 Performance
Former Sponsor
at $2k with front/rear camber set, I would do the following
Hotchkis sways, Koni yellows, Tein S Techs or Tanabe GF210's, and a set of endlinks. You'll get far better overall ride quality and handling vs a cheap set of coilovers, it will come in under budget, which will let you put some $ aside for alignment/install or a set of proper tires
