let's give the nismo some reliability mods...
Old Jun 1, 2009 | 04:18 PM
Ataru074's Avatar
Ataru074
Default let's give the nismo some reliability mods...
setrab 19 row oil cooler, mocal 180F thermostatic sandwich plate, spa design dual gauge (oil temp, water temp), greddy 52mm gauge mount, nismo PS cooler.
<a href="http://picasaweb.google.com/lh/photo/5OtwUWIq07MFl2pOQJ31bQ?feat=embedwebsite"><img src="http://lh3.ggpht.com/_txRK3mmWgA0/SiBdBAyOKGI/AAAAAAAAFGc/RyHA6SVY_mc/s800/IMG_0254.jpg" /></a>
<a href="http://picasaweb.google.com/lh/photo/v8PB9XbIhPN8aOfP4MCkXw?feat=embedwebsite"><img src="http://lh4.ggpht.com/_txRK3mmWgA0/SiMQi_l9loI/AAAAAAAAFG4/Awg_qLv8DX4/s800/DSC01733.JPG" /></a>
Old Jun 1, 2009 | 04:31 PM
Spork's Avatar
Spork
Nice
Old Jun 1, 2009 | 04:32 PM
Nexx's Avatar
Nexx
but... Solo said that the almight HR NISMO Z does not need cooling mods like the 370 does for the track....
Old Jun 1, 2009 | 05:13 PM
Ataru074's Avatar
Ataru074
without bashing on somebody or playing the fanboy game...
how in the hell anybody without water temperature and oil temperature gauges know if overheats in certain condition or not?
in texas summer I'm not even sure isn't going to overheat the oil even with a damn huge cooler.
for sure... is going to keep oil temperature at a more reasonable value and considering that there is a oil/water heat exchanger, is going to help (for how it's possible) the water.
I had my ps fluid boiling last year in a tight track ( grand sport speedway )
I had water boiling in the same track
I had differential fluid boiling pretty much every time before I switched to 80% lock and had the plate WPC treated
and I had clutch fluid boiling at texas world speedway last event...
so... I don't think that my oil is in a better shape... I just don't know.
Old Jun 1, 2009 | 08:15 PM
mthreat's Avatar
mthreat
Are you going to TWS this weekend June 6-7? I'll be there, but probably without my car due to my tire issue.
Old Jun 2, 2009 | 04:31 AM
Ataru074's Avatar
Ataru074
I'm not sure the mechanic could do the job on time... he's working on some lemons car for the race in Louisiana next weekend.
but I'll know that later this afternoon, I'll let you know.
I'll be at MSR for the texas Z party on the 20 and probably the following week at TWS.
edit: no tws this weekend
Old Jun 2, 2009 | 04:47 AM
JasonZ-YA's Avatar
JasonZ-YA
lets be nice nexx.............
-J
Old Jun 3, 2009 | 10:55 AM
Nexx's Avatar
Nexx
-J
just pointing out what someone claimed J.
i wasnt being mean, just bringing up a point for conversation purposes.
props to OP for doing it right.
Old Jun 3, 2009 | 02:25 PM
NISMO_558's Avatar
NISMO_558
It doesn't, maybe the OP just wants extra cooling.
Old Jun 3, 2009 | 02:45 PM
Ataru074's Avatar
Ataru074
I don't know if during the summer gets around 100F in minnesota... in texas it does... and if you use the car on a track the oil gets too hot really fast.
on the road of course isn't needed.
Old May 19, 2010 | 07:40 AM
NismoZ_840's Avatar
NismoZ_840
The HR can and does overheat engine oil on the track, even at cooler ambient temps (~50F). I've recorded 280-285 regularly during 20-30 min sessions. That's 370z limp mode territory. Also I'm short shifting around 6k-6.5 because flogging the car for a few more HPs isn't worth it to me.
How's the 19 row doing for you Atauru (max temps)? I'm thinking about a Setrab 25 row Series 9 or 34 row Setrab or Earl's. Can anyone comment in fitting these sizes into the 350z Nismo? I know the trick on flipping the Yamaha damper or possibly pulling it (prefer not to pull it though). Will be using a thermostat sandwich plate and Aeroqip socketless hoses w/ AN10 fittings. Any comments on the hoses? Thanks!
Old May 19, 2010 | 02:23 PM
Lakeside's Avatar
Lakeside
Good choice honestly! If I lived in Texas, these mods would also be high on my list. Not so much the power steering cooler unless I tracked my car but definately the oil cooler... An oil cooler is always a wise choice. Your adding capacity and cooling all in one!!! There is no denying they prolong the life of engines!..
One of my favorite sayings as an amatuer marine biologist/reefer is "The solution to pollution is dilution."
Thumbs up in my book
Zim
Old Aug 26, 2010 | 02:35 AM
KingBaby's Avatar
KingBaby
Hardest Setting
bump!
Old Aug 26, 2010 | 03:49 AM
JasonZ-YA's Avatar
JasonZ-YA
how has the nismo ps cooler worked in keeping the ps from boiling???
I semi don't believe in it as its only a two row pass system, only a wee bit bigger than the oem unit?? wondering if it has done the job?
curious??
-J
Old Aug 26, 2010 | 04:40 AM
idrive_MD's Avatar
idrive_MD
curious??
-J
I was wondering if someone was gonna make a comment about it. Better than stock, but like you have shown there are better/cheaper alternatives. I still need to revise/improve my mounts for my DIY setup, but the original ones I made up are still holding strong. They're just not pretty.
Old Aug 26, 2010 | 05:25 AM
JasonZ-YA's Avatar
JasonZ-YA
^ Ya exactly..........the cost of the nismo PS cooler is up there in comparison....
plus the added rows in a DIY set up is certainly solving my problem..my fluid doesnt boil at all..
-J
Old Aug 27, 2010 | 11:52 AM
nismofreak1208's Avatar
nismofreak1208
Hey ataru074, where'd you purchase the greddy mounts at and did the SPA come with sensors?
