285/35/19 on Stock Nismo
Old Dec 21, 2009 | 12:38 PM
xxbobbyxx's Avatar
xxbobbyxx
Default 285/35/19 on Stock Nismo
Will 285/35/19's fit on a stock Nismo without rolling the fender.
(Rear tires)
Old Dec 21, 2009 | 01:21 PM
No I am afraid not.
Old Dec 21, 2009 | 01:34 PM
dkmesa350z's Avatar
dkmesa350z
yes
Old Dec 21, 2009 | 01:48 PM
Italianjoe1's Avatar
Italianjoe1
I'm running a 285/30/19 with tons of clearance, you should be fine.
You're not lowered, are you?
Also, what tire? Some are bigger than others for a given size.
Old Dec 21, 2009 | 02:56 PM
StevieZ's Avatar
StevieZ
If its lowered it probably wont clear w/o rolling fenders.
Old Dec 21, 2009 | 03:07 PM
NismoZ_840's Avatar
NismoZ_840
Yes, running Hancook V12s in that size, stock Nismo, with no rub or concerns of rubbing.
Sorry, I was mistaken on the size. I'm running 275s not 285s. I still think you'd be fine though. Seems like there is a guy here in Colorado running 295s without issue.
Old Dec 21, 2009 | 07:52 PM
nismomike's Avatar
nismomike
I am running 285/35/19, nd it works fine. Great, actually.
Old Dec 21, 2009 | 09:07 PM
white323nismo's Avatar
white323nismo
I'm running Hankook RS3 285/35/18 and it rubs like crazy. Got the fenders rolled. If you plan to lower the car, then YES a must roll.
Old Dec 22, 2009 | 04:18 AM
xxbobbyxx's Avatar
xxbobbyxx
Thanks guys. I don't plan on lowering it yet. So I think I'm gonna go with the Hankook V12's 285/35/19.
Old Dec 22, 2009 | 04:59 AM
NISMO462's Avatar
NISMO462
What are the specs on these wheels? I think he is asking about stock NISMO wheels.
Old Dec 22, 2009 | 05:02 AM
dkmesa350z's Avatar
dkmesa350z
How does that help the OP considering your wheels have a much more aggressive offset than stock nismo wheels?
OP - 285/35 will clear all day on your wheels, lowered or not, regardless if which brand tire you go with
Old Dec 23, 2009 | 08:54 PM
white323nismo
the rear are 18 x 10.5 and +15 offset. my bad
Old Dec 25, 2009 | 08:06 PM
whitt1's Avatar
whitt1
285/35-19 Kumho XS fit fine on stock wheels.
Old Jul 3, 2013 | 10:07 AM
bb17's Avatar
bb17
Necrobumping, i know, but currently in this same situation. Not a large variety of tires available in the stock 265/35/19 size so discount tire is recommending i look at 275 and 285's. What are the pros/cons of running the wider tire? Any specific purpose for doing so besides tire selectioN?
Old Jul 3, 2013 | 10:12 AM
jonny350Z's Avatar
jonny350Z
It's mostly for looks. You would also get more contact with the road. I went with Potenza S-04 pole possitions in 285/35/19 with stock suspension on stock wheels and it clears with no issues. I've taken corners at high speeds and have had no rubbing issues. I kind of wish I would've bought 295s.
Old Jul 3, 2013 | 10:20 AM
bb17's Avatar
bb17
How does it affect tread/sidewall geometry? does it give it a weird shape to be so much wider than wheel?
jonny350Z's Avatar
jonny350Z
found some pics...
Attached Thumbnails 285/35/19 on Stock Nismo-383506_10152885247050367_1889511311_n.jpg   285/35/19 on Stock Nismo-936993_10152885247385367_1037461627_n.jpg
Old Jul 3, 2013 | 10:23 AM
jonny350Z's Avatar
jonny350Z
It's actually NOT wider than the wheel. 265 have a stretched look and you can tell by this pic that you can go a little wider since the sidewall isn't "flat" and this pic is 285/35/19
Attached Thumbnails 285/35/19 on Stock Nismo-600807_10152885247785367_262518851_n.jpg
Old Jul 3, 2013 | 10:45 AM
bb17's Avatar
bb17
Thanks! What is the actual wheel width? I always see them called out as 19x10 but even the stock 265 is wider than 10" (10.43").
Old Jul 3, 2013 | 10:54 AM
jonny350Z's Avatar
jonny350Z
just had a blonde moment... sorry about that. The tire will be wider than the wheel but I was talking about the inner part which will actually be tucked inside the wheel. So it won't look or fit weird.
