KingBaby's Nissan Nismo #0191 'Lin'da'
Old Aug 20, 2015 | 09:44 PM
  #1021
KingBaby's Avatar
KingBaby
Hardest Setting
Originally Posted by 67ZNISMO
damn man! 2 ARC oil caps?
It's just lipstick on my turd of a car
Old Aug 24, 2015 | 06:34 AM
  #1022
kno's Avatar
kno
Sweet I wouldn't mind 2 oil caps. Rotate them each oil change lol. Btw how's the rear plate underneath the rear bumper coming along?
Old Aug 24, 2015 | 03:55 PM
  #1023
KingBaby's Avatar
KingBaby
Hardest Setting
just made the mock ups haven't cut anything and really the car is on the back burner for the time being...
Old Aug 31, 2015 | 03:11 PM
  #1024
Rubidium's Avatar
Rubidium
Originally Posted by KingBaby
I continue to buy pointless pieces as I wait on either GTR manifold swap or pending HR ITB kit....
*waits*
oh.....ITB, pretty! Lots of work though, GTR manifold would be interesting too.
Old Sep 2, 2015 | 12:52 PM
  #1025
KingBaby's Avatar
KingBaby
Hardest Setting
I just want either of the two lol the waffle manifold is the most depressing thing when it comes to Nissan manifold....
The doors are the heaviest single part on this car next to the engine and trans
as she sit's...
Pretty much I just keep removing things to force myself to keep on the path of racecar !
Old Sep 2, 2015 | 01:37 PM
  #1026
QuintonC's Avatar
QuintonC
I don't know why I'm not subbed to this.
In 4 more!
Old Sep 2, 2015 | 02:14 PM
  #1027
kno's Avatar
kno
Damn dude there isn't gonna be much of a car left, take it easy lol
Old Sep 4, 2015 | 04:57 AM
  #1028
Nismo350z#0310's Avatar
Nismo350z#0310
whoa, you've got that thing tore down quite a bit.
Roll cage soon?
Old Sep 4, 2015 | 12:56 PM
  #1029
KingBaby's Avatar
KingBaby
Hardest Setting
In 4 more!
Cause it's a horrible roller coaster lol
Lol hopefully just the awesome is left
Roll cage soon?
That's the plan
Old Sep 10, 2015 | 05:29 PM
  #1030
saywat?'s Avatar
saywat?
so wats the point if theres no track in hawaii? jus enjoy the car man lol
Old Sep 10, 2015 | 08:39 PM
  #1031
KingBaby's Avatar
KingBaby
Hardest Setting
because midnight street racer ...plus military never know where I'll go next !
Old Sep 12, 2015 | 01:59 PM
  #1032
sofakiing's Avatar
sofakiing
you've been stationed there forever! lol
Old Sep 22, 2015 | 11:02 AM
  #1033
KingBaby's Avatar
KingBaby
Hardest Setting
don't tell nobody
Old Oct 8, 2015 | 01:12 AM
  #1034
roplusbee's Avatar
roplusbee
Must be Navy. Army wouldn't get away with that one......
Old Oct 8, 2015 | 01:59 AM
  #1035
Future Z owner's Avatar
Future Z owner
This looks epic, subbed and hoping to see updates soon.
Old Oct 28, 2015 | 09:23 PM
  #1036
KingBaby's Avatar
KingBaby
Hardest Setting
But the time has come as my squadron is moving to Whidey Island end of next year
No more paradise
Thank you, but it's not there yet !
Solidifying a mod by welding shut unused nipples. While I was back there trimmed several brackets and remove a huge bracket located on the driver side rear of the motor (1lbs)!
Old Oct 29, 2015 | 03:24 PM
  #1037
nismofreak1208's Avatar
nismofreak1208
I'm in the Army and I've been here 10 years. I even met kingbaby and we had a little touge run on our 1st meeting, it was magical, we had a blasian experience.
Old Oct 30, 2015 | 10:01 AM
  #1038
KingBaby's Avatar
KingBaby
Hardest Setting
Nice man ! It's magic every time we meet....with our cars !
My most memorial memory was when you had your custom exhaust setup, I remember Ina night cruise being blocked off by other cars and I couldn't see you, but every time you accelerated , my god ! All I heard was a screaming VQ so I knew you were near...
I'm pull my fuel tank out...trying not to touch the subframe, PAIN
Old Oct 31, 2015 | 02:43 AM
  #1039
roplusbee's Avatar
roplusbee
Must be nice. I was admiring the pictures and reminiscing of my time there. I would loose my mind if I was stationed there now.
Old Nov 1, 2015 | 08:25 PM
  #1040
KingBaby's Avatar
KingBaby
Hardest Setting
It is a beautiful place , haven't drove my car in a while but the roads are so rolling and scenetic that no drive is boring ! Even with two kids asking a millionth questions or a wife telling her latest drama... The roads cancel all that out !
The next MOD is only possible if you have delete the speaker box area. I'm in the process of dropping the fuel tank to cut it in half, without dropping the subframe !
So if you've removed I we speaker box the two volts should be visible. You would need to create a bigger box to use tools .
Below are quite from a memeber on the other site currently doing the mod.
Originally Posted by synolimit
Ok in less than 45min I unbolted the CBE from the X pipe, removed the W and Y braces, removed the crazy light carbon drive shaft, heat shields and disconnected the E brake. Moving nicely.
Another quote
Ok the tank took about an hour alone. Pretty easy as its only held in by two straps and 3 hoses but the two 17mm strap bolts have zero room to remove from below which are above the subframe. I had to take two nuts and from inside the car, lock them together around the threads sticking up from underneath and then loosen them. Then below I could remove with my fingers holding the tank up with my other arm.
So much room! My heads spinning with all the activities we can do! So many activities!!!!
Whole body can fit!
So I plan to drop mines tomorrow and figure out how I will mount both sensors! He welding a whole new stem to mount the driver side from.
Things continue to get dumber !
