Brandon3434's 350z Nismo #0277
Old Mar 22, 2011 | 09:05 PM
  #101
brandon3434's Avatar
brandon3434
^^^Yea I'm still under the engine/powertrain warranty...But are you sure you dont have to drop the tranny??? Explanation please because I couldn't figure it out today when I was under the car...
Old Mar 22, 2011 | 10:50 PM
  #102
musubi's Avatar
musubi
Yikes, sorry to hear about the slave.
Edit: I just noticed that you're running the JWT clutch and flywheel setup. That being said, I highly doubt Nissan will be covering that under any warranty. Maybe the recall? Also, if you were running the stock slave, it was probably only a matter of time before the slave blew. JWT seems notorious for blowing stock slaves on HR's. Since it's aftermarket, I would highly recommend you go with custompartz's heavy duty metal slave.
And I'm pretty sure the trans needs to be dropped since the CSC is inside the housing.
Let us know how things go. Good luck with the situation!
Last edited by musubi; Mar 22, 2011 at 11:14 PM. Reason: Noticed you're runing JWT setup
Old Mar 23, 2011 | 05:37 AM
  #103
BoomerZ33's Avatar
BoomerZ33
damn bro that sucks your slave gave out. the warranty will save your *** with this one. here's the recall:
https://my350z.com/forum/vq35hr/3281...-cylinder.html
and yes you do have to drop the tranny because on the 07+ the CSC is located inside the tranny bell housing. for the 03-06 it's more easily accessible.
Old Mar 23, 2011 | 05:56 AM
  #104
brandon3434
Thanks for the tips guys, that makes sense about the JWT owning the slave...So heres the deal. I called a few dealerships...Basically the car had already had the recall performed (I believe in 08) before I was the owner. Also, that's apparently not a part of the transmission so the warranty wont cover it. Thankfully I can do the work myself, but I didn't want to pay for the parts. Since the CSC is located in the tranny, I'm gonna have to pull it, but it seems like it wouldn't be too hard...
Old Mar 23, 2011 | 06:32 AM
  #105
brandon3434
And for the sake of forum entertainment...Here is what I am getting. I should never have this issue again...hopefully!
Old Mar 23, 2011 | 06:44 AM
  #106
jerseystyle's Avatar
jerseystyle
In for a detailed write up with a ton of pics!
Old Mar 23, 2011 | 06:45 AM
  #107
brandon3434
You know it! haha
Old Mar 23, 2011 | 09:24 AM
  #108
KingBaby's Avatar
KingBaby
Hardest Setting
Glad it's not gonna rape you!
And two thumbsup for doing it your self!
Old Mar 24, 2011 | 05:15 AM
  #109
brandon3434
The shop should get the part in Friday, so hopefully next week I can get the slave cylinder and get started...Need to get this done ASAP!
At least the car is aligned and everything else is in tip top shape!
Old Mar 24, 2011 | 05:40 AM
  #110
KingBaby's Avatar
KingBaby
Hardest Setting
nice neighborhood!
Old Mar 24, 2011 | 07:30 AM
  #111
brandon3434
^I'll trade ya?
Old Mar 25, 2011 | 06:11 AM
  #112
Slick 6MT's Avatar
Slick 6MT
Car is looking great!
Originally Posted by JDM_Tuner
is the colored reflection on the headlights natural reflections or was it just added in when photoshopping the pictures?
Just asking because ive seen that on many other pics or 350z's and when i take hi-res pics of my car theres no reflection like that
FYI: The rainbow effect on the headlights is from the polarized lens on the camera.
Old Mar 25, 2011 | 07:39 AM
  #113
KingBaby's Avatar
KingBaby
Hardest Setting
but you can see the rainbow effect with the bare eye...
Old Mar 25, 2011 | 08:07 AM
  #114
brandon3434
Glare from the sun/light? Also, Demon Eyes maybe? Its gotta be the way you are looking/taking pics of the headlights in the light...
Old Mar 31, 2011 | 02:46 PM
  #115
Kcee91's Avatar
Kcee91
That sucks man...I hope I don't get the csc failure on my 08. Looks good overall!
Old Apr 1, 2011 | 07:08 AM
  #116
jerseystyle
I think it was only an issue on the 07's but I could be wrong
Old Apr 1, 2011 | 07:40 AM
  #117
brandon3434
^^^Well heres a little update that may answer some questions. Basically, my stock slave cylinder could not handle my JWT clutch. Apparently, this is a common problem for any HR transmissions with an aftermarket clutch. Anyone with any kind of aftermarket clutch is prone to this kind of failure.
Here is a link for more info, which will explain why this part is needed for aftermarket clutches...After researching some, its definitely a great product to have that apparently hasn't failed on anyone yet.
https://my350z.com/forum/vq35hr/4749...-and-info.html
Oh and btw, still waiting on the part...
Old Apr 1, 2011 | 09:34 AM
  #118
Kcee91's Avatar
Kcee91
Thanks for the info man! Hope it goes well!
Old Apr 1, 2011 | 10:48 AM
  #119
mistanismo's Avatar
mistanismo
Hopefully everyone learns by now when your clutch goes if youčre going aftermarket get this slave kit... sure, you can drop the trans whenever assuming you have the know how and space but it's avoidable if you're going aftermarket for a couple hundred bucks while you're down there.
Pics and log would be great though
Old Apr 2, 2011 | 01:32 PM
  #120
Kcee91's Avatar
Kcee91
How's the SC going?
