Nismofreak1208's Silver Nismo Z (#1208)
Old Aug 4, 2011 | 05:07 PM
  #101
jerseystyle's Avatar
jerseystyle
Looks/sounds great! So what's in the container?
Old Aug 4, 2011 | 07:56 PM
  #102
nismofreak1208's Avatar
nismofreak1208
In the container is my type 2 voltex wing with 275mm stands and MCR canards (+a laundry list of parts from z1auto)
Old Aug 4, 2011 | 08:23 PM
  #103
nismofreak1208
Attempted to install the BCR harness bar but kept running into problems when aligning the bolt to the other side of the car and so after about 6 hours, we ended up having to get another bolt, unbolt the other side (which was good), then manage to bolt the problematic side up just fine. Then ran into the same problem on the GOOD side and only after two minutes of trying to thread in the bolt, ended up stripping the hole on the b pillar.....yup......we tried our best but somehow it just kicked our butts. Hopefully tmrw it'll be on and everything will be good to go! I shall update as the products slowly get installed.....
Old Aug 4, 2011 | 08:29 PM
  #104
KingBaby's Avatar
KingBaby
Hardest Setting
Still frustrated!
<----mechanical pride has been severly damaged!
Old Aug 4, 2011 | 09:23 PM
  #105
nismofreak1208
hey rod, what part were you talking about that i buy from courtesy nissan? Not the bracket hole thingy for the door, something else that were we talking about that u told me was cheap....i forgot wat it was but it seems like it was important.
Old Aug 4, 2011 | 10:24 PM
  #106
KingBaby's Avatar
KingBaby
Hardest Setting
This page
http://www.courtesyparts.com/350z-pa...5_863_864.html
This part number = 86868M
http://www.courtesyparts.com/kb_sear....php?keywords=[86868M]+\(z33&cPath=714_715_863_864
Old Aug 4, 2011 | 10:47 PM
  #107
nismofreak1208
no no no no, not that part, it was some other part i was looking for before we ran into any problems with the bar, it was not bar associated
Old Aug 4, 2011 | 10:53 PM
  #108
nismofreak1208
Can anyone with a regular Z verify this part below as the third brake light on the Z's that sit on the top part of the inner rear window. I looked at mine and since i'm going to be replacing my rear wing and losing that light, i was gonna purchase the light that goes up there. I've seen the chargespeed Z with that light so i just wanted to make sure it wasn't an aftermarket thing.
http://www.courtesyparts.com/350z-pa...5_751_764.html
Old Aug 5, 2011 | 04:06 AM
  #109
jerseystyle
Sorry to hear about your issues. Seems like the BCR bar is super high Can't wait to see all the other goodies installed!
Old Aug 15, 2011 | 12:43 AM
  #110
nismofreak1208
Flat Black headlights with halo and demon eye...COMPLETE
Old Aug 15, 2011 | 01:01 AM
  #111
KingBaby's Avatar
KingBaby
Hardest Setting
awesome...
Old Aug 15, 2011 | 01:20 AM
  #112
nismofreak1208
Rod, could you link me to the info about spacers and the need to do and such? I'm gonna pull the trigger on some wider spacers....
Old Aug 15, 2011 | 04:29 AM
  #113
jerseystyle
Headlights look great. Who did the work?
Old Aug 15, 2011 | 10:26 AM
  #114
nismofreak1208
A local member of our VQ INC did it. He's a G owner but started doing the headlight work for both Z's and G's. I'll try to take a pic of it in the daylight once i get off work.
Old Aug 16, 2011 | 11:35 PM
  #115
nismofreak1208
Just installed the 380RS gas pedal today, took me more than 1 minute due to the fact that I had to remove the stock black fastener on the lower part of the pedal and transfer it to the new pedal. So, took me 5 minutes, but here she is!
Old Aug 17, 2011 | 12:23 AM
  #116
nismofreak1208
btw, don't mind the light, i needed to see what was going on and this was a completely RANDOM install i did at night for no reason.
Old Aug 17, 2011 | 04:33 AM
  #117
jerseystyle
Awesome. I have the same mod.
Old Aug 17, 2011 | 08:18 PM
  #118
nismofreak1208
Xmas came early for me today
Old Aug 17, 2011 | 11:03 PM
  #119
KingBaby's Avatar
KingBaby
Hardest Setting
Out and about...
shaking the dust off!
http://www.youtube.com/watch?v=hJHYcCv2ryU
http://www.youtube.com/watch?v=Y-nqk4ySKM0
http://www.youtube.com/watch?v=8Aam0W8f8Xk
Old Aug 17, 2011 | 11:21 PM
  #120
jerseystyle
I totally need to deploy again!
