07/08 NISMO Z suspension question
Old Feb 10, 2011 | 07:39 AM
scardeal's Avatar
scardeal
Default 07/08 NISMO Z suspension question
I hope someone here can answer my question.
I know that the Nismo Z has additional welds/reinforcements/etc., revised shocks and springs, wheels, and body kit.
I want to know if the Nismo also uses metal bearings on the suspension instead of rubber bushings, or if it has different suspension geometry than a regular Z.
Thanks.
Old Feb 10, 2011 | 11:27 AM
350Z, Esq.'s Avatar
350Z, Esq.
By metal bearings do you mean heim joints?
Old Feb 10, 2011 | 11:47 AM
KingBaby's Avatar
KingBaby
Hardest Setting
answer to your question...is No.
Old Feb 10, 2011 | 05:47 PM
ChuckW's Avatar
ChuckW
Kingbaby is right. You can turn the wheels to the sides to check out the front bushings. You can literally crawl under the back end of the car to see the rear suspension bushings; there is plenty of room under there.
You'll see black rubber on all the bushings.
Old Feb 11, 2011 | 08:12 AM
dcastillo819's Avatar
dcastillo819
Dont really know havent taken mine off. I know I have seen metal small bearing in the rubber mounts before when taking other vehicle struts out. They were badly worn and just popped off they went everywhere.
Old Feb 11, 2011 | 10:20 AM
scardeal's Avatar
scardeal
Thanks! It looks like the main advantages of a Nismo Z over a regular Z in SCCA BSP competition then are the unibody reinforcement/rigidity and body kit.
Does the Nismo Z REMOVE anything from the interior? Does it not have the storage behind the seats or the rear wiper?
Old Feb 11, 2011 | 12:00 PM
KingBaby's Avatar
KingBaby
Hardest Setting
answer to your questions...is
No.
Yes.
Yes.
Go check one at a dealership. I'm sure there's a couple at a local meet...I always let true enthusiast drive my car so that they get a full idea of the difference!
Old Feb 11, 2011 | 10:55 PM
nismo333's Avatar
nismo333
No, but the ride is a bit harsh at times
Old Feb 19, 2011 | 10:49 AM
Paint It Black's Avatar
Paint It Black
On my nismo there is a damper/stiffener mounted in the front of the car and if you lift up the back panel that hides the spare there is another unit there, both units are made by Yamaha, you can definitively feel the road, but I like the feedback
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
