Stock Nismo Wheel
Old Sep 18, 2012 | 04:58 PM
Kels's Avatar
Kels
Default Stock Nismo Wheel
Question: Are stock wheels from the 2008 350z Nismo Powder coated or painted?? Like I'm talking straight from the factory original. Rays forged wheels
Old Sep 18, 2012 | 06:15 PM
lgear080's Avatar
lgear080
painted k11
Old Sep 18, 2012 | 07:00 PM
Kels's Avatar
Kels
2nd question: if the original Rays wheel was dented or scratched, should you paint them or have them powdered coated? The big debate is whether the paint will chip off.
Old Sep 18, 2012 | 07:19 PM
KingBaby's Avatar
KingBaby
Hardest Setting
curb rim will get curbed again...I'd hold off...just touch it up!
Old Sep 18, 2012 | 07:22 PM
Kels's Avatar
Kels
Well mine were hit by another car and the body shop is repairing it and I thought for sure they were powder coated but now I find out it's painted. So...now I'm confused as how they are supposed to fix the wheels
Old Sep 18, 2012 | 08:34 PM
Nismo1534's Avatar
Nismo1534
Paint is fine. Just be careful when having tires removed and installed. I just tell the tire shop that the factory paint is delicate and prone to chipping if they aren't careful.
https://my350z.com/forum/north-west/...ft-nw-ftw.html
Old Sep 19, 2012 | 10:10 AM
Nismo350z#0310's Avatar
Nismo350z#0310
To answer your question: Powdercoat.
Why? Because I had the Rays wheels with curb rash. Horrible chips too. I had them powdercoated and It basically fixed them. Look black and brandnew. The best part about powdercoat is it is not delicate like paint and can hold up a lot better.
Most places will sandblast it before they powdercoat which also helps the look. I only paid $40 per wheel.
Here is an example:
This wheel had horrible curbing and now looks brand new.
Example of all four.
Old Sep 19, 2012 | 11:13 AM
tkuntz's Avatar
tkuntz
I take it your wheels were painted and not powder coated? If they sanded down the scrapes and scuffs, how did they keep the contour of the lip as if nothing had happened?
Old Sep 19, 2012 | 11:47 AM
Italianjoe1's Avatar
Italianjoe1
If it's done properly, you really won't notice. Also, if the damage is severe, they usually fill it by welding before any extensive sanding is done. Not a fan of that on a forged wheel but it looks much better than a low spot from sanding.
Old Sep 19, 2012 | 02:28 PM
tkuntz's Avatar
tkuntz
Hmm intriguing.
I would go powder coat if you can get it to match the finish of the rest of the wheels, if not just paint them... I have ran into the issue of paint chips from getting the rubber replaced and it sucks!
Old Sep 20, 2012 | 12:25 PM
Nismo1534's Avatar
Nismo1534
Yeah, I had one wheel painted and the shop did a great job blending in the lip/contour of the wheel because they had to sand down half the circumference of the lip - you couldn't even tell it had been fixed when it was done! Then, I had another wheel done that was only spot sanded and you can tell where it was sanded down if you look really close because the contour is slightly off.
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
