Nitrous Oxide Too soon, jr.
how do you avoid spraying in 1st with a WOT switch?
Old Dec 28, 2004 | 09:00 AM
sentry65's Avatar
sentry65
the burninator
Default how do you avoid spraying in 1st with a WOT switch?
sorry if this is a newbie question, I've read about 2/3 of all the nitrous posts here so far
Just assuming the car can get traction under normal NA WOT in 1st gear, but you don't want it to spray in 1st cause that would break the tires loose - what do you do?
I know you can just not floor the pedal in 1st and wait until you're in 2ndto floor it, but is there another way to get your full NA power out of 1st without spraying??
Old Dec 28, 2004 | 09:21 AM
mrtomcat's Avatar
mrtomcat
You can get a NX Maximizer.
This unit allows you to program how much to spray in what gear. You can slowly increase the percentage per gear.
The other goodies included are: window switch, tps switch, gear based control, A/F safety cut off.
You can monitor and program it via a Palm Pilot
here's a link:
http://www.nitrousexpress.com/Pages/Maximizer.htm
Old Dec 28, 2004 | 09:30 AM
sentry65's Avatar
sentry65
the burninator
awesome, thanks
I've read people mentioning the maximizer, but never knew what it was
thanks!
Old Dec 28, 2004 | 04:44 PM
Mean Gene's Avatar
Mean Gene
Default Only NX?
Tomcat - Does the Maximizer only work with NX kits or will it interface with ZEX, Edelbrock, etc?
Gene
Old Dec 28, 2004 | 06:06 PM
weslutes's Avatar
weslutes
I wired a push button to my throttle position sensor that turns off power when held down.I mounted the buttonon my foot rest.(I have an auto)
the nitrous kicks in when I let off the button,then the WOT sensor and window switch do the rest.
Attached Thumbnails how do you avoid spraying in 1st with a WOT switch?-dsc00776.jpg
Old Dec 28, 2004 | 07:36 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Very interesting setup, I like it.
Old Dec 29, 2004 | 06:44 AM
TheBigShow's Avatar
TheBigShow
just flip your activation switch after you shift into 2nd.
Old Dec 29, 2004 | 02:43 PM
mrtomcat's Avatar
mrtomcat
Default Re: Only NX?
Gene
I believe it works on any kit, NOS has one similar as well. I'm just a NX fan, it's been good to me
Old Dec 30, 2004 | 05:02 AM
Mean Gene's Avatar
Mean Gene
Default Maximizer
Tomcat - I just spoke with Jon @ NX & he said the Maximizer would work with any nitrous kit. That's all I needed to hear so mine's on order right now!!
Gene
Old Dec 30, 2004 | 02:52 PM
mrtomcat's Avatar
mrtomcat
very cool!!!
Old Dec 31, 2004 | 10:53 AM
weslutes's Avatar
weslutes
I looked at the maximizer at a few different places and they all wanted at least $500! That's a waste of money if you ask me.
my switch costed $9 & the wires were less than $10
I guess you can take your left hand off the wheel,or your right hand off your shifter to flip the power in the middle of a run.That just doesn't sound safe to me,but I guess you manual guys have no choice
Old Dec 31, 2004 | 02:49 PM
mrtomcat's Avatar
mrtomcat
If you buy the components that are build in seperately it goes like that:
window switch: $130
TPS Switch: $100
A/F Safety: $300
Gear Sensor controller...well, there's none seperate
Programmable shot precentage...again not there seperate
Palm Interface...none available
so that makes it beyond worthwhile
In addition, I for once want to spray in 1st, just not the full shot so the fact that you can gradually increase is the trick here, it allows for better control and traction and safety which is something that your $20 switch and manually switching can not accomplish.
I don't know you but I have to tell you that when I'm at the track there's enough to focus on. Having to turn on another switch after shifting is not something I want to do.
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
