Nitrous newbie
Before i get jumped with the search ****** i did search and i read almost every thread in this section before posting. I just want everyone's opinion.
I have a few mods, stillen exhaust, kinetix V4, kinetix highflow cats, AEM intake, JIC clucth, stillen aluminum flywheel.
I was looking into runnin a 50 shot or so and this is the info i gathered that i will need. (correct if wrong).
NX EFI wet kit
NX window switch
NS TPS switch
NGK LFR6A-11 plugs
Presure guage
Bottle warmer (is this optional or necessary?)
Purge
any tips or hint or problems i will run into along the instal? i plan on attempting it myself one weekend. thanks for the input
NX EFI wet kit
NX window switch
NS TPS switch
NGK LFR6A-11 plugs
Presure guage
Purge
That looks about right.You may need a relay switch.The msd window switch might be a little cheaperThe Zex kit comes with the TPS.That reminds me.....
I do have an extra complete Zex kit sitting right here for sale.If you wanna buy it for cheap, I'd be willing to sell.
i haven't heard many reviews of the ZEX kit. how do you like yours and what is the difference between the ZEX and NX kits, because one looks like a PITA to install and one looks pretty simple.
also the zex comes with the TPS switch and the NX does not.
also the MSD window switch... does that work right out of the box with pills or does it have to be sent off and tuned?
[QUOTE]Originally posted by spdu4ia
[B]i haven't heard many reviews of the ZEX kit. how do you like yours
---Mine works great.Perfect A/F
---They are both a PITA to install.I guess the Zex is easier because it has a WOT switch and the cylinoid all built into the main controll unit.(less pieces & wiring)
---Yes.WOT or TPS switch, whatever you want to call it.The Throttle Position Sensor wire is located on the throttle body plug(I had a good signal from the white wire)
---Yes, it works right out of the box.No pills or tuning.Its prettty basic
stick with NX they are just hands down better and the shot is at the wheels.
You need the NXGenx II kit (blow down, fuel shut off, purge, bottle warmer, pressure gauge)
don't get the NX window switch get the Mallory or the MSD
NX TPS is great and or course the NX EFI import kit as mentioned above
xtort
Apr 18, 2003 06:37 AM
