Nitrous Oxide Too soon, jr.
Nitrous
Old Aug 18, 2005 | 09:16 AM
traub83's Avatar
traub83
Default Nitrous
I have a 04 350z base 6 speed coupe,
Anyways I purchased a nx nitrous kit for my car adjustable from 35-300hp. anyways i was thinking a 150hp shot, I will be upgrading the clutch and flywheel here within the next 3 weeks to a act street clutch and a findanza aluminum flywheel. will my motor be able to handle 150hp shot if tuned properly? also what kind of times are people pulling in there z's with nitrous only? i know this is really braud but the nitrous will be a track use only also..
Old Aug 18, 2005 | 01:07 PM
raptorbh12's Avatar
raptorbh12
with good traction tires you will be around low 12's to high 11's with a 150 shot. And your right you will need a good tune or an ecu reflash for it. 2 step colder plugs would be necessary too. ALso when running through 150 shot you might want two tanks so you dont run out so fast.
Old Aug 19, 2005 | 09:58 AM
traub83's Avatar
traub83
there will be a cpu reflash done, 2 stage colder plugs, and i will start off with a low shot and work up to the 150 shot, so im looking pretty good and low 12's is exactly what i want. cause i dont wanna do a cage in my car and im an IHRA track so 11.99 and im screwed..
eskimo
Nitrous Oxide
282
Jan 30, 2011 03:22 PM
amg_diananet
Nitrous Oxide
Sep 19, 2003 08:30 PM
cyberz350
Nitrous Oxide
Jun 20, 2003 06:05 PM
EmpiricalGMan
May 26, 2003 06:39 PM
