Nitrous Oxide Too soon, jr.
Pictures of your NOS install?
Old Oct 9, 2005 | 01:38 PM
james840a's Avatar
james840a
Default Pictures of your NOS install?
Anyone got any pictures of there nos install?
I think about doing one in my car, and need some ideas.
thanks
Old Oct 9, 2005 | 06:28 PM
BoOsTedz33TT's Avatar
BoOsTedz33TT
Old Oct 9, 2005 | 06:50 PM
james840a's Avatar
james840a
Boosteds33tt, what shot you running? and was it worth installing one?
Old Oct 9, 2005 | 08:25 PM
Dubai's Avatar
Dubai
Old Oct 10, 2005 | 09:58 AM
james840a's Avatar
james840a
Ok guys, i found the perfect spot for my Nos tank. Since my sub sets right in front of the strut brace, and the amps mounted behind that. I have a nice size void were the stock sub goes, and the tank will mount nicely side to side. I know thats not the idealy way to mount it, but it will look stock, and no tank visible. Plus it is easy to get in and out to re-fill, I did a dry run with placement with my tank. Now i have to do is save up for the other parts. I may see if i can get the Zex system with out the tank. Keep my cost down.
Thanks for the pictures and ideas
Old Oct 30, 2005 | 06:19 AM
BoOsTedz33TT
nitrous is fun for about a couple tanks, i went turbo. total difference. I had a 100 shot, and if you dont have optimum pressure, the bottle on all the time, and a bottle heater your not gonna feal that big of a difference. Turbo is the way to go
Old Oct 30, 2005 | 07:31 AM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
the bottle fits in the sub compartment? hmmm, i cant visualize that but that is nice. I am thinkin about a 100 shot.
Old Oct 30, 2005 | 08:11 AM
Vamos_Rafael's Avatar
Vamos_Rafael
that double bottle set up looks NASTY~
Old Nov 18, 2005 | 07:49 PM
D350Z10's Avatar
D350Z10
+1, Is one for spray and the other for purge?
Old Nov 22, 2005 | 03:45 PM
03track's Avatar
03track
anybody got pics of where they you mounted your solenoids? how bout toggle switches?
Old Nov 22, 2005 | 06:38 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
ill take some tomorrow, mine are all under the right hand battery cover, when i get done with the direct port, you wont be able to see any of it.....
Old Nov 22, 2005 | 07:14 PM
Ep3's Avatar
Ep3
how are you doing direct port you have that kenitix plenum?
Old Nov 23, 2005 | 02:17 AM
Audible Mayhem
My350z
i am direct porting it into the lower plenum on the inside of the V that it makes. cant do it on the outside because of the fuel rails, i just have been working everyday, all day long, so i havent had time. i will take some pictures of that too, i am doing a soft port on the lower plenum also. just taking out about a mm all the way around and smoothing in out with an 80 grit, then cleaning it up. it just takes a while to do and my job is really busy this time of year...
Old Nov 23, 2005 | 05:34 AM
03track's Avatar
03track
Brilliant!
Old Nov 26, 2005 | 12:07 PM
MySunset350Z's Avatar
MySunset350Z
heres some bad phone pics of my bottle, new switch panel (old panel is in avatar), and an old pic of the nitrous and purge seleniods. i've since moved the seleniods but everything else is the same. 2 years no problems (knock on wood).
Attached Thumbnails Pictures of your NOS install?-468352630_orig.jpg   Pictures of your NOS install?-468411735_orig.jpg   Pictures of your NOS install?-q.jpg
Depravity
Oct 1, 2015 04:49 PM
