Nitrous Oxide Too soon, jr.
nitrous + twin turbo kit
Old May 26, 2006 | 12:59 PM
q8pianist's Avatar
q8pianist
Default nitrous + twin turbo kit
hi guys
im planing to ran 150 shot and my twin turbo car. but i dont have any info how to do it.
Old May 26, 2006 | 01:06 PM
NissanZfan's Avatar
NissanZfan
Have you built up your engine?
Old May 26, 2006 | 04:24 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
you might want to do some reading up first....
Old May 26, 2006 | 05:01 PM
nissansource's Avatar
nissansource
lol 150 on TT how bout read some info on FI + N20 figure u start out with 20-30-50 max
Old May 26, 2006 | 05:07 PM
Gators2001's Avatar
Gators2001
I would use lesser of a shot and tapper it off... to compensate for the lag of the turbos...
Old May 27, 2006 | 05:43 AM
Nowell's Avatar
Nowell
National Z Club
Sorry, but you aren't going to find a kit with big enough turbos to see any lag. On some kits like the JWT, your almost into full boost by 1700 rpms.
Old May 28, 2006 | 01:48 PM
q8pianist's Avatar
q8pianist
my mods r :
JWT cam and springs with shims, ported heads, Crank balanced, Main and Rod bearings w/ceramic coating, ARP Rod Bolts, heads and main studs, cosworth gasket, eagle rods, cp 8.5 pistons with rings,
this mod is the same in sgp racing stage 3 long block,
my twin turbos are the ultimate turbo kit.
im planing to run no2 but i realy dont have any info about how much or how to do it
Old May 28, 2006 | 01:52 PM
trefling's Avatar
trefling
I"m running a 50 shot with my supercharger and I can tell you that on the dyno a 50 shot works out to be almost exactly 100 additional hp/tq on the dyno. So a 150 shot would probably be a bad idea because you can expect that to traslate into 250-300 at the wheels and with a turbo you better have one well built motor or your heads will probably float and you'll end up in trouble.
Old May 28, 2006 | 02:02 PM
Audible Mayhem
My350z
if you are serious, i would run a 75 shot MAX outta the hole on the track with slicks. anywhere else is going to be a complete waste of tires and time....
i would hit the 75 shot right when i left and have it with a reverse progressive tapering off almost instantly. it will help you with a nice launch but i would rather have the power up top with a turbo then nitrous.
if you can add nitrous to your top turbo hp then you need to turn the boost up more...
i dynoed 170 ft pounds of torque on a 100 shot
Old May 29, 2006 | 02:59 AM
q8pianist's Avatar
q8pianist
ok guys now i get it
50 is a good target
thanks to u all for helping me
