Nitrous Oxide Too soon, jr.
wot signal wire....which one??
Old Sep 28, 2006 | 01:56 PM
eltness350's Avatar
eltness350
The Untouchable
Default wot signal wire....which one??
my z is procharged and i put a nitrous express intercooler sprayer on it. i cant seem to find which wire is the wot signal wire...i heard u can use the sensor on the gas pedal?? through the cpu or throttle body?? im not sure...does anyone have this application and any info would be great...thanks in advance
Old Sep 28, 2006 | 05:32 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
its the green wire on the throttle body if i am not mistaken, i would just put it on a whole other switch if i were you and cool it down WAY before you floor your car.
just my opinion
Old Sep 28, 2006 | 08:59 PM
first350's Avatar
first350
the TPS wire is on pin 50 of the ECM...I tapped into the wire @ the Throttle body (I think it was green with a white stripe). I'd double check the manual to make sure your year has the same wire coloring.
if you have a multi-meter, you can double check that you have the correct wire:
-engine off, key turned to 'on' position, manual in 1st gear:
1) accelrator pedal up: ~.5V @ tps wire
2) accelrator pedal fully depressed: ~4.5V @ tps wire
-Peter
*I have the manual on my laptop, os if you have a +'04.5 model, let me know and I can double check the wiring color tomorrow morning.
Old Sep 29, 2006 | 05:54 AM
tenpenniesz's Avatar
tenpenniesz
+1
Old Sep 29, 2006 | 01:22 PM
eltness350's Avatar
eltness350
The Untouchable
thanks guys...much appreciated!!
Old Oct 24, 2006 | 11:22 AM
97supratt's Avatar
97supratt
Do you guys know the color of the wire for 06's?
FromGtoZ
Sep 20, 2015 03:41 PM
pdexta
Sep 14, 2015 11:27 AM
Bigsyke
Sep 11, 2015 06:19 PM
hardwood66
Sep 8, 2015 04:31 AM
Daniel_dh
Sep 7, 2015 12:56 PM
