Nitrous Oxide Too soon, jr.
New Zex window switch question
Old Jan 4, 2007 | 04:15 AM
Derek Dee's Avatar
Derek Dee
Default New Zex window switch question
Does anyone know if the Zex traction control window switch can be used with the Zex brain box?
You would think so, but the Zex site does not mention anything about compatibility with the brain box.
Anyone?
Increase engine safety and optimize nitrous boost for maximum traction
Looking for the power to select the precise rpm for nitrous system activation? The new ZEX™ Traction Control Window Switch lets you easily select the rpm range of nitrous system activation, both lower and upper rpm limits. The ability to set this rpm “window” is critical to engine safety because engaging the nitrous below 2500 rpm can cause detonation and engine damage. In addition, hitting your engine’s rev limiter with the nitrous engaged can lead to dangerous intake system backfires.
The ZEX™ Traction Control Window Switch is a completely self-programmable and fully electronic component which can be easily adjusted up to 20,000 rpm, making it perfect for any application, including high-revving motorcycle engines. Incorporating ZEX™ Skip-Shift technology, the ZEX™ Traction Control Window Switch allows you to block out first gear nitrous activation where excessive power could cause lost traction, especially with street-tire class racecars. With Skip-Shift, the nitrous injection is held off until the shift is made into second gear (and subsequent gears) where the nitrous power can be fully utilized.
Old Jan 4, 2007 | 05:20 AM
Old School's Avatar
Old School
Shift_Boost
A couple people have put the Zex window switch on the zex box. Not sure how to wire it to that as I use NX. If you haven't bought it already, check out dynotune nitrous tps/window switch.....that is who manufacturers the zex. Its $100 cheaper and is EXACTLY the same thing.
Old Jan 4, 2007 | 02:56 PM
Derek Dee's Avatar
Derek Dee
Thanks for the info...I will check into the DynoTune.
Old Jan 4, 2007 | 03:04 PM
GodZilla's Avatar
GodZilla
Bad Mojo
I used MSD window switch with mine, doesnt have any kind of traction control though..
Old Jan 4, 2007 | 08:02 PM
Derek Dee's Avatar
Derek Dee
I think the shift skip is a great idea..... off to do more research....
thanks for the input all.
Old Jan 8, 2007 | 09:38 PM
Mc556's Avatar
Mc556
I second the dyno-tune box it is the same box for less money ..
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
