Nitrous Oxide Too soon, jr.
Show your jets!
Old Jul 30, 2008 | 04:07 PM
silver350tn's Avatar
silver350tn
i think i am going to lower the fuel to a 26 and up the nitrous to a 47 and i usually run race gas when i spray to prevent detonation
Old Jul 31, 2008 | 07:05 PM
2boosted4u's Avatar
2boosted4u
honestly i say just get a wide band o2 and play with the jets make sure never to go under 12.5 (from what ive heard) and dont spray under 3000 MAX...i was stressn when on the dyno they were sprayn around 2200!!! lol well seee how everything works out..for now i need tires lol
Old Jul 31, 2008 | 07:15 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
If I were you, I'd keep the "minimum" rpm to 3500 (for safety). Also, the higher the AFR, the leaner you are. Lean condition is bad for nitrous. Being rich isn't as bad but you risk pooling of nitrous/fuel mixture. So, you shouldn't go leaner than 12.5 is what you mean. Personally, I'd shoot for 11s.
Old Jul 31, 2008 | 07:18 PM
2boosted4u's Avatar
2boosted4u
yea sorry thats what i ment yea i know i was pissed at the dyno guys but thats what they have to do to get numbers i guess..oh well i guess well see what the future has in store for my z lol
Old Aug 27, 2008 | 03:44 PM
silver350tn
my jets now are a 48 nitrous and a 36 fuel. is this too rich? i just put my order in for an innovate wideband so i can monitor the air/fuel coming up pretty soon
Old Jan 31, 2009 | 11:24 AM
3hree5ive0ero
Retired Admin
Bumping an old thread with my information:
Nitrous&Fuel / Octane / Timing / Dyno #s / AFR / E.T.&Trap
48N 32F / 93 / -2º / 304.6 whp & ??? tq / ~11.3 / 12.520@110.17 mph
(lost bottle psi toward the end)
54N 42F / 93 / -2º / 315.3 whp & ??? tq / ~11.8 / TBA
This was done on a dynojet, but the dyno couldn't read my torque numbers for some reason. It said my max tq was 211.
Old Jan 31, 2009 | 11:40 AM
I am JDM's Avatar
I am JDM
40n 24/93/stock/???/???/12.8 108mph with a bad clutch or stock goin bad
Old Feb 18, 2009 | 12:51 PM
JZK's Avatar
JZK
I have an 08 Z, so I'm running two nozzles... The jet sizes that are currently in are
38/22 on each nozzle. So it'd be 76/44 (Dynotune 125 shot) However it's running rich, so I just ordered a pair of 20 fuel jets, I'll post up once I install them.
However right now it's: 76n 44f / 93 / -2 / TBA / 10.6-11.0 / TBA
Old May 22, 2009 | 11:25 PM
3hree5ive0ero
Retired Admin
54N 42F / 100-105 / -2º / 315.3 whp & ??? tq / ~11.8 / 12.330@111.69mph(high humidity and less than favorable temp)
Updating mine. Still no tune.
Old Jan 11, 2010 | 09:07 PM
MTZ33's Avatar
MTZ33
48N 28F / 93 / -2º / 348.8 whp & 408 tq / ~11.8 / TBA (need tires)
Dynotune Nitrous w/ bottle heater... Tuned by Japtrix w/ UTEC
Old Jan 11, 2010 | 11:06 PM
3hree5ive0ero
Retired Admin
Updating mine again.. I still don't have a tune (stock ECU with only 2 degrees pulled via somebody else's AccessPort).
54N 42F / 100-105 / -2º / 284 whp & 367 wtq / ~11.8 / 12.288@109.67mph (as of Dec 20, 2009)
This was on a Mustang Dyno at Cobb. My first pull was N/A and my car put down 237 whp 232 wtq. 2nd pull, I made 284/367 with very low nitrous in the bottle on top of my tires slipping triggering the VDC!!! The damn noobie dyno operator left that on. 3rd pull was rendered useless thanks to the empty bottle. I'll redyno again properly in a few months.
My set up as-is should be good for 12.0 or even 11.9 down the 1320'. I just got a new clutch/flywheel so once I get a bit more seat time, I should be able to get a better ET.
Old Jan 12, 2010 | 04:57 PM
MTZ33's Avatar
MTZ33
^^ ur 1/4 mile times sick! i need a clutch ASAP n ill see wat i do... u got nice #'s regardless tho... the torque is awesomeeee on these bottle fed z's!!!!
Old Jan 12, 2010 | 05:22 PM
3hree5ive0ero
Retired Admin
Thank you, sir. Drag racing's been my hobby ever since I got my Z. Hopefully, I'll have some accurate dyno numbers with a full bottle and with the VDC off pretty soon to match up with my ET/trap.
I only had 1 trip out to the strip since my new clutch/flywheel went in but I can already tell you that lightweight flywheels make launching the Z noticeably harder (since we nitrous guys launch N/A and then juice gets sprayed, thus not enough power to overcome the bogging from the reduced flywheel weight). If you're planning on daily driving and drag racing only, then stick with the stock flywheel.
Old Jan 12, 2010 | 06:11 PM
MTZ33's Avatar
MTZ33
Yea i heard bad things and good things bout light weight flywheels.. ill prolly jus get the jwt clutch kit and keep my oem fly... should be good for a bit.. and btw, for a mustang dyno, ur #'s arent bad at all but ur right, should be a bit higher for the nitrous jet u got in there.. goodluck with it!
Old Jan 12, 2010 | 10:41 PM
3hree5ive0ero
Retired Admin
Sounds like you got it all planned out.
Yeah, my horsepower number is low because I was losing pressure before it could hit its peak. I got the torque surge, though.
Old Jan 14, 2010 | 07:28 AM
BakaN20's Avatar
BakaN20
Maybe its time for NANO , lol. I can't wait to see what your setup gets you!
Old Jan 14, 2010 | 10:04 AM
3hree5ive0ero
Retired Admin
That's for ballers only, like you. I'm no baller.
When can we expect to see some drag race times from you anyway?
Old Jan 16, 2010 | 01:50 PM
  #38
BakaN20's Avatar
BakaN20
On another forum I am on, someone is selling their brand new 4500 psi NANO kit with a zex 10lb bottle for $400.
I have to wait and see how much money I have this summer. I should learn how to drive first, like you said, learn to handle the current power, but I am just going to build instead, lol. I hope to be finished by summer and actually drive the car, lol.
Old Jan 16, 2010 | 07:59 PM
  #39
Hostetler's Avatar
Hostetler
47-30/93/stockish/340whp 344tq/10.6/unknown
i gotta step down the fuel jet and timing down about 1.5-2 degrees...now that i have one step colder plugs and the massive vacuum leak fixed, she should be pushing some better numbers next time I throw it on the dyno
Old Jan 16, 2010 | 08:44 PM
  #40
tollboothwilley's Avatar
tollboothwilley
What is the scare with having your window switch set lower than 3000 rpms?
