Nitrous Oxide Too soon, jr.
Where did you mount your purge kit?
Old Aug 24, 2007 | 05:30 AM
r3zon8's Avatar
r3zon8
Default Where did you mount your purge kit?
looking to get ideas where most Z owners are mounting a purge kit.
Ive got the Zex single purge, and after the solenoid it just has a straight steel tube...can i bend it? can i extend it?
...with its fixed length and unable to bend it im really limited to where and how i can mount it...help!
Old Aug 24, 2007 | 05:55 AM
skwid's Avatar
skwid
I used a longer steel tube and had it mounted in the cowel. It's hidden and sprays up out around the windshield. It's basic and simple.
Old Aug 24, 2007 | 06:05 AM
r3zon8's Avatar
r3zon8
please post PICS if you guys have them..
thats what i was thinking...i could mount the solenoid under all the black pastic right under the windshield and have the tube stick out from there.
Old Aug 24, 2007 | 06:30 AM
skwid's Avatar
skwid
http://www.skwiz0d.com/pictures/dyno/purge.jpg
Old Aug 24, 2007 | 08:03 AM
RebelinRI's Avatar
RebelinRI
^ Can you get a little closer, it's hard to see.
Old Aug 24, 2007 | 09:16 AM
garym's Avatar
garym
I bought some black, high pressure 1/8" tubbing and compression fittings, and a T-fitting to run dual purge.
I mounted the ZEX controller and the purge valve inside the Master Cylinder compartment.
There is a hole in the bottom/back of the M/C compartment that I ran the tubbing through. There was another small hole in the fender wells behind each tire. I ran the tubes out the small fender well holes pointing straight out the sides, on the backside of the well nearest the firewall.
If you've ever wired a car stereo, you would remember the V-shaped clips that the screws twist into for the speakers. I took a couple of those clips, drilled them out just enough to fit over the 1/8" tubbing. I squeezed them with pliers and slipped one over each end of the tubing and back about 1 inch. The V-clips lock onto the hose when released so they hold the tube in place so the spray pressure doesn't blow the hose back through the hole.
So when I spray, it shoots out the sides from inside the fender wells.
My system is completely hidden. Even the switches are under the dash out of site.
Old Aug 24, 2007 | 11:09 AM
RebelinRI's Avatar
RebelinRI
Where's is your clutch fluid reservoir to cram you for space?? Must nice to have an auto, for this at least.
Old Aug 24, 2007 | 01:34 PM
garym's Avatar
garym
LOL!
He never said if he had manual or auto.
I've always used Auto's in drag racing for consistency, so I stuck with an auto when I got the Z.
At least the Z has more then 2-speeds.
HoBrahYouStink
Jun 24, 2016 10:58 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
