Nitrous Oxide Too soon, jr.
Nitrous Kit Finished but... Help Please
Old Dec 21, 2007 | 07:35 AM
RebelinRI's Avatar
RebelinRI
Sorry been bust but the flashing is not correct. The tech asked if the power and ground switch are shared. They need to be on an insulated/seperate circuit otherwise it could pick up a noise signal. He also thought that the power ground that the unit maybe loose or intermitant. The 111 solid lights (not flashing) is correct depending on what you have the unit set for. The led's left to right indicate as follows:
A = Throttle position activation switch status [0 = off / 1 = on]
B = Gear lock out for channel 1 [0 = feature off / 1 = locked out]
C = Gear lock out for channel 2 [0 = feature off / 1 = locked out]
Hope this helps and it's an easy fix for you.
Old Dec 21, 2007 | 08:19 AM
pimpin714style's Avatar
pimpin714style
Interesting Read.im About To Go Nitrous So Ima Keep This For Info.
Old Dec 21, 2007 | 08:22 AM
RebelinRI's Avatar
RebelinRI
Have you read the sticky at the top of this section too? Great read. Big thanks to JT for putting it all together.
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
