Nitrous Oxide Too soon, jr.
Water/Meth Injection on Spray
Old Feb 18, 2008 | 10:14 PM
BabyZiLLa's Avatar
BabyZiLLa
Default Water/Meth Injection on Spray
Well i purchased all my goodies for my Wet 100 shot. All dynotune. Bottle warmer, remote opener etc etc.
For that size shot i'm guessing i should be pulling 3-4 degrees of timing in the window switch rpm range correct?
My thought was to run 50/50 water/meth injection when on the nitrous so i did not have to pull any timing.
What do people think of this? I know water/meth injection with nitrous is a pretty common setup.
Cheers
Old Mar 2, 2008 | 11:25 AM
chefrey's Avatar
chefrey
i would still pull 4 degrees and strap up to a dyno and make a couple of pulls adding a .5 degree back at a time untill you get a knock then back out 1.5 degree. you should be able to run more timing then someone without the water/meth kit but everycar is different so to be safe i would try what i sugested above. also you can run a higher percentage of meth in your mix for better results.
Workshop12
Mar 23, 2020 01:45 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
roadmax
Sep 12, 2015 05:55 PM
