Nitrous Oxide Too soon, jr.
Questions about install...
Old Feb 29, 2008 | 01:51 PM
hershell's Avatar
hershell
Default Questions about install...
Do you need to use some kind of RVT / rubber gasket when installing the fuel tap?
It seems to me that the oring should seal it, but it is leaking.
Do you need the fuel pressure safety valve/ switch installed when running n20 with a TXS UTEC?
Thanks for any help.
Old Feb 29, 2008 | 02:27 PM
garym's Avatar
garym
Check the O-ring.
Mine split the first time I installed it. It caught the edge and cut it in two,
Fuel Pressure safety switch is always a good idea, but it's not needed with some kits, like ZEX. Zex has one built into the control box.
Old Feb 29, 2008 | 03:39 PM
hershell's Avatar
hershell
Thanks. I looked at the o-rings and they look good. It's a NX kit.
Old Feb 29, 2008 | 08:12 PM
garym's Avatar
garym
What fuel tap are you using?
Old Feb 29, 2008 | 08:25 PM
hershell's Avatar
hershell
The Dynotune
Old Mar 1, 2008 | 09:25 PM
garym's Avatar
garym
Hmmm,
They shouldn't leak. You might cal Dynotune and see if they have an idea.
Only thing I could see causing a leak is the o-ring either being split or damaged, or a flaw in the cast of the unit itself.
Old Mar 4, 2008 | 07:44 PM
tenpenniesz's Avatar
tenpenniesz
I bet it's the o-ring. I had the same problem and couldn't figure it out. Ended up jus treplacing the o-ring and it fixed the problem. Sometimes they look okay but can still leak. Give it a shot if you are still having problems. It's a cheap enough option.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
