Nitrous Oxide Too soon, jr.
Quick Question
Old Mar 7, 2008 | 09:45 AM
carlos305's Avatar
carlos305
Default Quick Question
Will you blow your engine on a 100 shot if you miss a gear?
Old Mar 7, 2008 | 10:04 AM
garym's Avatar
garym
Not if you're using a Window Switch or some sort of management that cuts the nitrous at a specified RPM.
I use a window switch with a max RPM of 6800.
If you're not using anything and the rev limiter kicks in, it reduces the flow of fuel, which can cause a lean burn, and that can be catastrophic with nitrous.
Someone said in another post that the rev limiter cuts fuel completely so theres no chance, but why chance it?
Old Mar 7, 2008 | 11:03 AM
RobbieG35's Avatar
RobbieG35
I'm with him. Get a window switch, or try to be very careful when your shifting with just a WOT switch.
Old Mar 21, 2008 | 05:28 AM
r3zon8's Avatar
r3zon8
what window switch is most commonly used? which is easy to install/program?
Old Mar 21, 2008 | 07:17 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
The Dynotune window switch/throttle position sensor seems to work well and it is very easy to program, as are most other ones.
Old Mar 21, 2008 | 08:37 PM
Aced16's Avatar
Aced16
get a UTEC! you can tune for window switch and WOT 2!
lapham3
Oct 7, 2022 03:15 PM
issyz
Jul 2, 2017 03:04 PM
