Nitrous Oxide Too soon, jr.
pulling timing?
Old Aug 7, 2008 | 09:00 PM
silver350tn's Avatar
silver350tn
Default pulling timing?
how are you guys pulling timing? i am on stock timing right now and i am about to up my shot a guy at a nissan dealership he can alter the ecu but only up to 2 degrees i guess thats my only option for right now, whats everyone else doing?
Old Aug 8, 2008 | 11:53 AM
frankie945's Avatar
frankie945
Buy a Utec you can even control your nos with it to.
Old Aug 8, 2008 | 12:44 PM
coachk's Avatar
coachk
Retard timing 1.5 - 2 degrees per 50 hp shot. What size were you running on stock timing and what are you upping the shot to??
Old Aug 8, 2008 | 02:25 PM
I am JDM's Avatar
I am JDM
i can use a snap on modis or solus scanner or matco determinator and adjust the timing. i was thinkin of doin that but im probably gonna go utec its cheap
Old Aug 8, 2008 | 02:36 PM
silver350tn
a buddy of mine just altered it 2 degrees for me and upping to a 100 shot
Old Aug 9, 2008 | 12:40 PM
Ruthless18x's Avatar
Ruthless18x
I will need to retard my timing as well soon. How hard is it to do yourself on a UTEC? Would it be as simple as loading a map for similar mods? I'm just not comfortable having any of the shops in AZ tune for my nitrous.
Old Aug 9, 2008 | 12:55 PM
Hoooper's Avatar
Hoooper
can you control other brands of nitrous with it too?
Old Aug 9, 2008 | 04:05 PM
BakaN20's Avatar
BakaN20
Check out Uprev's Osiris. Seems to be quality and working well.
Old Aug 9, 2008 | 08:49 PM
genegoesfast's Avatar
genegoesfast
All the UTEC does is apply the ground to the solenoid when certain user determined values are met. It will work with anything that needs a ground.
Old Aug 12, 2008 | 07:24 AM
Ruthless18x
I would rather control my nitrous with the dedicated Zex window switch and TPS, but I can also run the UTEC to retard timing and correct A/F, correct? No conflicts sense they are running separate, right?
Old Aug 12, 2008 | 11:33 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
That would be like having an N/A map, except with timing pulled. You'll just be spraying in that map.
Old Aug 13, 2008 | 07:26 AM
genegoesfast
the beauty of the UTEC option is that you dont have to run a sluggish NA map all the rest of the time (that you're not spraying). Also it's an additional insurance policy when you use the UTEC as your window switch, without having your nitrous map loaded the nitrous can't fire no matter what. A valet or any other driver wouldn't have the ability to fire nitrous due to the Utec having a different map loaded.
Obadabot
Jun 18, 2023 11:31 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
